OT: What planter is this?
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Topic: OT: What planter is this?
    Posted: 08 Jun 2010 at 10:55am
Does anyone know what planter this is? It has no markings or name plate. It has  an aluminum body
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 6:58pm
Don't know who made -- but it looks like a pretty decent tool. Does it have plates that go with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 11:42am
I think that the center round thingy with the wing nut is a plate of some kink. Got to soak it to get the rusted wing nut off to disassemble. This post has been viewed 199 times but only your reply. Must be a rare piece of equipment i have here!
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 8:23pm
Some disassembly help.  Using an OXY-Acetylene torch, light only the acetylene side and blacken only the area that you're going to heat up (around the screw).  Next finish lighting the torch and adjust to an acetylene rich mixture.  A rosebud tip works best.  Heat the desired area until the black changes to yellow and then almost disappears.  Hold a candle against the screw and immediate area to get wax down in the threads.  Let cool.  The screw may back out now with normal torque.  If screw offers too much resistance, repeat heating process.  The heat breaks the bond between the steel screw and aluminum.  The wax helps prevent the aluminum threads from coming out with the screw.
Ed
