b allis hub center nut
wkiheri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Topic: b allis hub center nut
    Posted: 05 Sep 2016 at 10:48am
does anyone no how much torque you can put on the center nut hub of a b allis I have tightened it with a least 100 foot lbs and the hub is still a little bit loose or do I have to add another shim washer between the nut and the lock washer
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:00am
If you are talking about the rear wheel center nut you should not need shims unless it has been run loose and wallowed out the splines on the stub axle and hub. At this point you could try a shim but I do not believe it will help also you probably could use 200 ft.lbs torque o.k. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:06am
Ok, thanks I was afraid of that. Do  you think it will to run it a little bit loose
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkiheri Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:07am
i forgot the word loose
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2016 at 11:49am
Don't run it a little loose, it will get worse.
Use a Big washers or whatever it takes to get it tight.
