185 final drive adjustment |
Post Reply |
whatscooking
Bronze Level Joined: 08 Oct 2017 Location: Indiana Points: 47 |
Posted: 05 Jun 2018 at 1:22pm |
How do you go about tightening up the shaft that your wheel is bolted to on the final drive on a 185?
Nathan (SD)
Orange Level Joined: 11 Sep 2009 Location: Day County SD Points: 1260 |
Never done a 185, but the other AC tractors have shims on the end of the shaft. Take the center plug out of the final drive and take out the bolt that goes into the wheel shaft. Should be shims under the washer. Remove the appropriate amount and then re-install the bolt and cover.
whatscooking
That's what it looked like under the cap. I was changing the fluid in the pans and have some movement when I grab the wheel at 12:00 and push and pull.
MACK
I would guess one of the two bearings are flailing. MACK
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8239 |
Agree with MACK.Unless someone has fiddled with it prior,it would have been correct from factory so looseness indicates bearing loosing material.Those are not that hard to work over.Once you remove cap with shims,you can drive axle out to inspect brgs.Some fit tighter than others.Bull gear will drop out bottom when axle is removed.It only fits one way because of hub. My advice is from dealing with a WD45 but they are the "same".
whatscooking
Two shims and it snugged it right up.
Burgie
Orange Level Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Good job Mark.
"Burgie"
whatscooking
Thanks Burgie, I did it like you said, take one out try it.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29781 |
Probably still a bad bearing that will be out after a while. I've seen two 185 axles break from a heated bearing. (I'm assuming heat caused it) I repaired the one 185 myself while working at the Allis dealership. Have never seen any other Allis axle ever break but these two different 185s in my area did. Oh, and a 7060 with long axles and running with a chisel plow and a flat inside dual.
Edited by Lonn - 13 Jun 2018 at 7:22am |
Wink I am a Russian Bot |
SteveM C/IL
Dad's 49 WD broke both axles within 5yrs of each other in mid 60's.New ones had more meat where they broke.
Post Reply | |
