A few 190XT questions. |
Post Reply | Page <12 |
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2900 |
wow that's crazy. They were lucky. Do you know what caused it to flood so fast?
ezlle71
Silver Level Joined: 22 Jan 2018 Location: Kansas Points: 62 |
Around here creeks can rise and fall in just a few hours. The water had receded the next day we pulled both tractors out. Crazy stuff here in the flint hills.
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
ezlle71
Got another question, Can anybody tell me where a good place to tee into the hydraulics on the 190XT for a loader without using one of the remotes?
Really don't wanna tie up one of the remotes for the loader all the time as we plan on puling the field cultivator with it. thanks |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3786 |
a loader valve with power beyond tapped into the pressure line in front of the tractor valve stack. power beyond then runs to tractor valves. discussed on here many times, a search would probably yield several discussions.
ezlle71
Sorry about that. I should have searched |
ezlle71
What's the trick to searching on this forum? having a difficult time getting results
CAL(KS)
you can do a google search also if this doesn't get you what you want
"adding loader valve on 190" site:www.allischalmers.com search topic in " " this brings up a bunch of topics Edited by CAL(KS) - 04 Apr 2018 at 12:06pm |
ezlle71
Surplus center has 3 different GPM loader joysticks. 10, 12 and 25. Would the 12 gpm be sufficient for my 190xt? From what i looked up the hydraulic gpm of this tractor is 12 gpm. I searched the forum and have the procedure for connecting to the tractor figured out.
ezlle71
Wanted to give alittle update. Thanks to several people here, i got the 12 gpm surplus center joystick all plumbed in and operational. Have been very happy with the results all summer. The XT got to field cultivate, round bale, swath hay, drill sudan grass even got hooked to the plow alittle bit. Got some side shields from Abilene Machine. And at the request of the hired man and my dad, the XT now wears a 200 muffler. I will admit the muffler makes the tractor alot more enjoyable to operate. For next year, a sun shade was requested by the hired man.
During prairie hay mowing, the radiator sprung a slight leak. So i am gonna pull it and have it professionally cleaned and repaired. And gonna replace the water pump while its out, have new hoses all ready for it. While on that subject, i have heard of people using a different fan on these tractors for more or better air flow? if anybody can confirm that? Because i would make that switch too while i'm at it. Thanks ez
Orange Level Access Joined: 12 Sep 2009 Points: 20185 |
More airflow to accomplish what ?? If you aren't having overheating issues as it is, why change anything when it comes to the fan ?? There's a reason a model 200 has two fan belts.....the different fan pulls harder.
ezlle71
She was running alittle warm this spring working ground. 210-220 degrees pulling the 22 ft krause field cultivator about 6 mph. Maybe having the core of the radiator rodded and cleaned will take care of it. It would cool right back down when i backed outta it. So maybe i was worried for nothing. How many blade fan should a XT have? It seems to really move air so that's why i was curious how much more air a 200 fan will move.
A good cleaning might take care of your problem. If your fan belt wasn't TIGHT, the belt may have been slipping at high idle. With the single belt at full throttle the belt has to be in good condition and tight.
ezlle71
Thanks Doc!
ezlle71
Had to put new rear tires on the XT last friday. Ouch. Got Firestone Super All Traction 2's in 18.4x34. Should be good to go for a while now.
