Generators
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Generators
    Posted: 11 May 2011 at 7:11pm
Sometimes it just doesn't pay to paint stuff. My generator worked before I took it apart for brushes and bearings. Somehow, I managed to kill the armture electrically. Now what? The same armature is in the D15D and '57 Chevy with P/S...
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 8:11am
Brushes sticking in the brush holder? Did you sand the brushes to fit the commutator? Did you connect the brush wires? Is a long brush wire hitting the case?
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 11:17pm
No, brushes are good. The amature is shorted. Jacobs in Newton was able to find me a new one. When I tried to motor it, it would jump back and forth before spinning slowly and drawing about 50 amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 6:31am
Gee Brian , I've got a starter for a 55-57 Chevy V-8 sitting here,original, then I figured you needed the generator...got one here as well....then finally read you're back in business.....lucky guy, I'm still looking for a 'G' starter armature...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:49am
Jay, you might try calling Colfax Tractor Parts here in Iowa. They had a Massey Harris Pony with a rod sticking through the side. Maybe they still have the starter...
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 9:52am
I know what you mean about the paint!!  I was working on my daughters Triumph Spitfire the other day and cleaned up and painted the perfectly functional starter while it was out.  After re-installing it, it no longer would work!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2011 at 10:01am
 I buffed the paint off where it shouldn't have paint, (including the commutator bars) still didn't work. Makes me glad i didn't take the starter apart. They called and and it's ready to go. Now the weather isn't cooperating. High temps in the upper 80's and low 90's earlier this week. Now it's not supposed to go past the upper 50's....
