gas tank cleaner
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: gas tank cleaner
    Posted: 06 Apr 2011 at 4:48pm
Has anyone ever used a mix of purex and vinegar to clean old gas out of a gas tank. I was told this by a radiator shop. I power washed the tank but it still has old gas smell. I will say that all but the very bottom came clean and shiney with no signs of rust. right in the bottom is old gas stuck like varnish.
allis restorer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis restorer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 4:50pm
You could try carb cleaner, just my thoughts. Steve
Go orange or Go home!!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 5:07pm
 Oven cleaner should dissolve it to the point you can hose the residue away with water, use acetone to remove the moisture.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2011 at 5:42pm
I think Phosphoric acid is what came in the Kreem kit that I used on my B. It worked really well but it might go too far for what you want to do?
Edited by wjohn - 06 Apr 2011 at 5:42pm
