Garage Door Safety Beam
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Garage Door Safety Beam
    Posted: 18 Jan 2025 at 9:54am
How do you semi-permanently defeat these? Is it simply a switch inside? Is just 2 wires each…Are the sensors typically interchangeable between brands? Got one Genie (not working right) and one Stanley working that I could use for troubleshooting. Need to be frugal for now!😎
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 10:53am
Mount them together nose to nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 11:31am
Yeah, in the process of doing that I ended up finding the broken wire!      Thanks
Edited by Tbone95 - 18 Jan 2025 at 11:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 11:58am
Mine are up above a couple inches apart. Small children and pets beware....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 12:45pm
The question really comes down to, if you had a bad one, can you fool the unit into thinking everything is fine.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 1:15pm
mounted mine above the door on the header pointed at each other, has worked for 30 years...Harvey
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 4:05pm
Tbone, i dont thing you can " wire around it".... everyone just tapes them looking at each other...... If one goes BAD, i think you are screwed..
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 9:58pm
I found this on the internet, SO IT MUST BE TRUE !
G
Use Reflective Materials
Reflective materials can be employed to bounce the infrared beam back to the sensors, creating the illusion of an uninterrupted path. For garage door sensor bypass. place reflective tape or similar materials on surfaces near the sensors to achieve this effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 10:03pm
that does NOT eliminate the sensor... that was his question.. reflexting the beam is useless... WHY ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 8:28am
Thanks Steve, I figured as much. As I mentioned, I found a broken wire and everything is working now, but while my thinking was getting ahead of my doing I was wondering if they could just be eliminated.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 5:27pm
I would have to study a schematic but there has to be a way to wire around it. It is simply sending a go/no go voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 5:35pm
um, it might not be a steady beam.....
I've seen them where the beam is actually pulsed ( high frequency ) so someone with a flashlight can't 'fake' the beam to open the garage door.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 5:45pm
its not an ON- OFF switch... If the door is OPENING and you stand in front of the beam, nothing happens... If the door is CLOSED and you stand in front of the beam, nothing happens.. If the door is MOVING DOWN and you stand in front of the beam, the door reverses direction.... There is LOGIC involved... not just OPEN- CLOSE ( on - off).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2025 at 7:31pm
Yes, I worked with photo eyes for years in the sawmill business, there are many types of photo eyes and not all of them use visible light, various frequencies, etc. The 'logic' is dealt with at the controller, the photo eye just says 'blocked/not blocked'.
Lacking the schematic and the ladder diagram it is difficult to know just where to tap into the system to defeat it. Maybe not a good idea anyway Tongue
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 3:19pm
It's a pulse transmit/receive signal train.  If the transmitter doesn't talk to the operator in the proper way, you won't get a 'clear to operate' signal.
It's easier to open up the operator, yank the controller, and put in a simpler controller.
The operator runs on three signals... first is the 'command to run', the second is the 'direction to run' switch (either up or down), the last is 'excess load', which is a spring operated switch.
The Command To Run is a simple momentary.  The Direction To Run is a two position toggle switch tripped by mechanical piece on the operator's mechanism (chain, gear, etc)... it's either in the UP, or DOWN position.  It serves two functions... first, is to allow operating in one direction, the other is to STOP it when running to the limit of travel. If the machine is running in the UP direction, and the direction switch is tripped to the DOWN position, the operator stops.
It's not a complicated machine, they just added complicated hardware to prevent it from being modified.
When you press the button, the command-to-run signal energizes.  The 'direction' setting engages either one wire (to go one direction) or the other wire (to go the other direction) for operating the motor.  In old machines, this is nothing more than a 24v relay with two sets of contacts... one of which is tied to it's own coil to serve as a 'holding' contact.  Press the button, the relay stays closed until power to the coil is cut off.  The other sends power to the direction relay... whose two outputs (up and down) are connected to the motor's up direction winding, and down direction winding.
The motor starts in the direction identified... and it continues to run until the operator's limit switch contacts the 'direction' switch... which flips the DIRECTION switch... causing the motor to stop... as the motor direction switch has a pair of contacts in it that the HOLDING contact is looped through.
The last circuit element is the 'excess load' switch... which is nothing more than a microswitch depressed by a slider that the door operator works against (like, a chain tensioner, or the motor bracket) such that when an excessive load (in either direction) occurs, the tensioner or bracket shifts, causing the switch contacts to open.  They're in series with the COMMAND TO RUN relay's holding coil.  Put it in an 'excess load' state, and the relay just shuts off.
ANY door operator can be gutted of it's 'excess technology', and fitted up to operate in a realistic way.
Defeating the photobeam is more complicated, because the door operator's 'excess technology' is there to make it so you cannot easily 'defeat' it with anything other than a toilet paper tube and some duct tape.
The whole 'door beam' thing came as a result of 'supposition' that a child or pet could get injured or killed by a closing door.  In reality, this never actually happened, because part of setting up the door, is adjusting the opening and closing forces... that 'excess force' switch has to be dialed up enough to lift the door (the counterweights and springs need to be set up right to make it work, right?), so the actual opening and closing forces are very low.  In reality, a person can place their foot under the door, and it senses and reverses automatically.
In reality, the danger part of overhead door operators, isn't the operator, it's the door.  Specifically, the weight fo the door, and the countersprings used to counteract the door's weight.  Injuries from overhead doors come in three flavors:
1) Countersprings exploding on fatigue failure... most of the time this happens when nobody is around
2) People injured while adjusting overhead door countersprings, frequently springs that fail WHILE they're adjusting them...
3) Doors with failed countersprings FALLING on people.
Notice that NONE of these problems can be solved by the presence of a 'safety beam'.
Most of the problems with the Safety Beam come from the door NOT closing... including freezing the home, home invasion, and theft.   The door doesn't close because the beam prevents it from allowing the door to close.
There's four categories of beam failure-
Obstruction (dust, dirt, leaves and cobwebs, frost, snow, and ice)
Electrical failure (broken wiring)
Beam system failure (transmitter or receiver going bad)
Jamming (headlights, streetlights, or sunlight glare overpowering the beam).
Notice that last one?  If I wanted to break into someone's home, I'd get a high-powered flashlight or laser pointer, set it up in a good position to glare that beam receiver, and when they went to close the overhead door, I'd wait 'till the door was almost all the way down, then I'd hit the flashlight (glare the beam) to reverse the door AFTER they'd walked into their house.  Now the door is open, the bad guys can walk right in.
The beam is more of a danger than a protector.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2025 at 3:30pm
Nice writeup Dave but you can't shine a light at my GD to get in..... well not unless it's IR and running at 2048 Hz. A solid beam of light (car headlight, flashlight,etc) has ZERO effect. Have an 8 pin PIC controlling 'access'.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 6:51am
Wise move, Jay... I've dealt with this problem on the systems at my folks' house.  On theirs, glare off the pavement jammed the sensors, causing the door to not close.  Too much technology for a 'safety feature' that has no actual standing.
That being said, it isn't a significant challenge for a hacker-kid to reverse-engineer an operator beam using an Arduino and a few off-the-shelf parts to do just that.  What used to take significant talent, now just takes a few minutes shopping online and download a few pieces of code.  Times have changed a whole lot since cramming assembler into the 16F84.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 7:07am
I've used toilet paper rolls in the past to eliminate the 'it's now fall,sun poke head aroud house, floods the sensor' problem. Drove me nuts as it was a 'random' event.
As for hackers, it really 'upsets' me that after 40-50 emails, NOBODY replies about my $5o anti-theft addition to any and ll vehicles being stolen. Truly 'hacker proof', no matter if they have the keyfob or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2025 at 8:05am
As usual, Dave does his superb explanation of how things work. Thank you Smile
Originally posted by DaveKamp DaveKamp wrote:
It's a pulse transmit/receive signal train.  If the transmitter doesn't talk to the operator in the proper way, you won't get a 'clear to operate' signal...
Yup. Ultimately a Go/No Go after all of the pulses, frequencies, etc.
When I was in the Marines a half-century ago I was an avionics technician (COMMNAV). The IFF systems we worked on used a complex combination of frequencies/pulses to code the signals, ultimately to (I)dentify aircraft as (F)riend or (F)oe.
Gateman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gateman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2025 at 4:14pm
Unfortunately, you cannot eliminate them the way it’s designed you can’t fake it. It’s an intermittent pulse signal.
Only option is mount them on the back of the motor one on each bracket coming down from the ceiling.
You can bypass them to close the door by holding the wall button down until it gets all the way closed, release the button just as it hits the ground and it’ll stay closed.
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 47 minutes ago at 7:21am
Well said; I totally agree.
When it comes to over-head doors, I have seen and experienced it all.
My father's huge tire shop had nine over-head doors, all of them big and two of them huge; the two largest were 20-foot wide and covered an opening 16-foot tall.
I have seen those big ones have a spring break and come slamming down.
I have seen springs break when standing on a ladder, wrenches and adjusting rods in hand. --- If you ever think a spring needs adjusting, you had best just replace it as it is probably on the verge of breaking.
And, I could not count the times when we would go to open a door and discover that the spring had broken sometime in the night when no one was around to get killed.
None of these doors were automatic; all were manual.
Edited by BuckSkin - 18 hours 45 minutes ago at 7:23am
