Garage Door Safety Beam
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Garage Door Safety Beam
    Posted: 18 Jan 2025 at 9:54am
How do you semi-permanently defeat these? Is it simply a switch inside? Is just 2 wires each…Are the sensors typically interchangeable between brands? Got one Genie (not working right) and one Stanley working that I could use for troubleshooting. Need to be frugal for now!😎
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 10:53am
Mount them together nose to nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 11:31am
Yeah, in the process of doing that I ended up finding the broken wire!      Thanks
Edited by Tbone95 - 18 Jan 2025 at 11:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 11:58am
Mine are up above a couple inches apart. Small children and pets beware....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 12:45pm
The question really comes down to, if you had a bad one, can you fool the unit into thinking everything is fine.
Harvey/pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harvey/pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 1:15pm
mounted mine above the door on the header pointed at each other, has worked for 30 years...Harvey
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 4:05pm
Tbone, i dont thing you can " wire around it".... everyone just tapes them looking at each other...... If one goes BAD, i think you are screwed..
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 9:58pm
I found this on the internet, SO IT MUST BE TRUE !
G
Use Reflective Materials
Reflective materials can be employed to bounce the infrared beam back to the sensors, creating the illusion of an uninterrupted path. For garage door sensor bypass. place reflective tape or similar materials on surfaces near the sensors to achieve this effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2025 at 10:03pm
that does NOT eliminate the sensor... that was his question.. reflexting the beam is useless... WHY ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 19 minutes ago at 8:28am
Thanks Steve, I figured as much. As I mentioned, I found a broken wire and everything is working now, but while my thinking was getting ahead of my doing I was wondering if they could just be eliminated.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 20 minutes ago at 5:27pm
I would have to study a schematic but there has to be a way to wire around it. It is simply sending a go/no go voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 12 minutes ago at 5:35pm
um, it might not be a steady beam.....
I've seen them where the beam is actually pulsed ( high frequency ) so someone with a flashlight can't 'fake' the beam to open the garage door.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 2 minutes ago at 5:45pm
its not an ON- OFF switch... If the door is OPENING and you stand in front of the beam, nothing happens... If the door is CLOSED and you stand in front of the beam, nothing happens.. If the door is MOVING DOWN and you stand in front of the beam, the door reverses direction.... There is LOGIC involved... not just OPEN- CLOSE ( on - off).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 16 minutes ago at 7:31pm
Yes, I worked with photo eyes for years in the sawmill business, there are many types of photo eyes and not all of them use visible light, various frequencies, etc. The 'logic' is dealt with at the controller, the photo eye just says 'blocked/not blocked'.
Lacking the schematic and the ladder diagram it is difficult to know just where to tap into the system to defeat it. Maybe not a good idea anyway Tongue
