G230 vs G226 |
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Topic: G230 vs G226Posted: 11 Jan 2016 at 12:02pm |
Does the Buda 230 gas have any advantage over the 226? More torque? Looks like it revs more.
Charlie
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3546 |
Posted: 11 Jan 2016 at 8:14pm |
could you narrow the question a bit. What are the uses of the power plants?
Charlie175
Posted: 12 Jan 2016 at 5:30am |
Say a WD45 Diesel but with a 230 gas vs a WD45 226
Charlie
Lonn
Posted: 12 Jan 2016 at 8:33am |
I've watched 230 gas powered tractors at the tractor pulls and they can really light up. That's the only experience I have had with them. Similar to the 262 in my D19. Nice smooth power in the 262 with good power but no where near the governor action as a 226.
Edited by Lonn - 12 Jan 2016 at 8:35am |
Wink I am a Russian Bot |
Posted: 12 Jan 2016 at 9:53am |
If there ever would have been a WD-55 or a D-18 tractor, my guess is, the G-230 might have been the engine of choice (at a higher RPM). As it was, the four cylinder did the job and probably cost less than a six cylinder.
Charlie175
Posted: 12 Jan 2016 at 10:14am |
Just dreaming on a cold day.
Charlie
Posted: 12 Jan 2016 at 12:55pm |
My vision for years of the WD-55 was the G-230 @1800 RPM with an 11 inch diameter foot clutch, an 8 inch diameter triple disk hand clutch and a 7 speed transmission with 3-speeds faster than each existing gear (for in-between speeds) except road gear, a longer wheel base and 16.9 x 28 tires. Could have been a real contender in the 53 HP class in 1953.
JoshL
Posted: 13 Jan 2016 at 11:52pm |
We ran a 262 in a cockshutt we had. They are strong motors.
Lonn
Posted: 10 Feb 2016 at 9:58pm |
Edited by Lonn - 10 Feb 2016 at 9:59pm |
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 08 Mar 2016 at 10:29pm |
back in the day a lot of the 262 gas were put in small dump trks. farm trks. etc, and worked well . Now if you took a 235 head, opened up the water passages in the end of the head and did nothing else you could work the heck out of the small V8,s. It really woke that little 262 up. Leon Cmo
