G spark plug |
w3grant ![]() Bronze Level ![]() Joined: 08 May 2025 Location: Ipswich Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2025 at 6:49pm |
I’m working on an Allice Chalmer G and three of the spark plugs are threaded directly into the head and one a spark plugs has a threaded spacer on it I have seen some pictures with them on it and some with them not are they needed and if they’re not needed what plug do I run?
Thanks Warren |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87090 |
normally the spacer is added for one of two reasons...
possibly .... Original threads in the head are bad so they loctite in a spacer permanent. then put the plug in it...
the MAIN REASON .....If the engine burns oil and fouls a spark plug, putting the spacer in , moves the plug out slightly and may keep it from fouling as often.. possibly never. |
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4794 |
Autolite 295 for the plug, you can use a 303 if you feel the need for a hotter plug
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11978 |
Turn that around Joe. The 295 is hotter than the 303. Go by the last digit for the heat range in Autolite. Obviously, 5 is higher than 3 so 5 being the hotter heat range. Your right in your assumption, hotter in a worn engine or oil control issue. As Stevo said, one of the two is probably the issue. Bad threads or bad rings in that one cylinder... Steve@B&B
LOL!, correct as always Steve, what do you expect, I’m getting older and forgetful
