G Rear Furrowing Bar
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Topic: G Rear Furrowing Bar
    Posted: 21 Dec 2010 at 7:24pm
Well, I finally got most of a rear furrowing bar. No, it's not complete and I gave to much for it but it's mine. (And the UPS man hates me !) Both tool bars are missing but I can bend steel, so no problem. The lift lever has been shortened, considerably ! Barely a foot above the Ratchet. Still, not a big  problem. Both right and left Plungers and the plunger block are missing. This is a problem ! Here's where the pix come in ! Are they the same as the front lift Ratchet and Block ? If so, I have the real thing to look at and should be able to duplicate. If they are different somehow, I'd appreciate a picture or two if anyone wouldn't mind. Thanks.
Oh, I also got two front drawbars, one factory original and one homemade. There really wasn't anything about a G that was 'light duty' was there ? The steel in this stuff is massive !
Scott(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 9:17pm
RH Master Lift Parts:
Spring, Plunger    Part# LTP-31  (same used for both plungers)
Plunger, Spring Box, Right     Part# LX-652
Plunger, Spring Box, Left       Part# LX-653
Block, Plunger Raising      Part# 303262
Guide, Plunger, Upper     Part# 308300
Bolt, Guide                    Part#308274
Rear Furrowing Bar
Plunger, Spring Box, R.H.    Part# LX-652
Plunger, Spring Box, L.H.    Part# LX-653
Block, Raising    Part# 303262
Bolt, Guide                  Part# 308274
Looks like all the part numbers match.
Best regards,
Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 7:36am
Thanks, Scott, good to know all the parts interchange. I just pulled the plungers from my G front lift. Any chance someone has a set they'd sell ? I doubt I can make them myself !
This page was generated in 0.093 seconds.
