G question(s) |
John Kenny ![]() Silver Level ![]() Joined: 06 Jan 2012 Location: Rhode Island Points: 56 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Apr 2012 at 5:39am |
I have a few more questions about issues with my old G. Any advice would be much appreciated.
1. recently replaced gaskets on carb, but when fuel line is open and tractor off gas leaks out of the lower gasket (at last inspection floats are good). 2. tractor seems to suck gas, how long should a tank of gas last in a G? 3. is it recommended to use leak-fixing additives to the oil pan? I have a slight leak at the back of the pan, possibly from the pulley. 4. does anyone have any good advice as to how to adjust the governor? Tractor idles poorly and governor seems to be really enthusiastic (RRROoowww, RRROoowww, RRROoowww). Thanks. john |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
1. the float may be dropping too far and sticking in the bowl.
4. Model G 117. ADJUSTMENT. With engine running at high idle, turn bumper spring adjusting screw (1—Fig. AC 52D) in until surge is just eliminated. Linkage adjustment consists of making sure that the system operates freely and that carburetor link rod (3) is long enough to put a slight preload on the governor arm when hand throttle and carburetor are in wide open position. This is done by adjusting rod (3) to a length 1/32 inch longer than required to connect its two attaching levers when the latter are in the wide open position. Engine High Idle Speed. . .2100 rpm Engine Loaded Speed 1800 rpm |
Sorry I can't copy and paste the image from a PDF file.
wbecker ![]() Orange Level ![]() ![]() Joined: 29 Oct 2009 Location: STL Points: 837 |
1. If it leaks out of the gasket, the gasket is not installed correctly, and the float valve is leaking. The fuel should not be as high as the carb gasket if the float valve is is doing it's job. 3. I would not but any kind of stop leak in the engine oil.
Bill B
mmccarty ![]() Silver Level ![]() Joined: 06 Feb 2012 Location: SW Wisconsin Points: 86 |
I've been plowing and discing with mine and a tank of gas lasts a long, long time, more than I'd expect it to. You're probably leaking most of the gas onto the ground or running it very rich.
I doubt that your governor needs adjustment. It's doing what it's supposed to do. You need to get the engine running better. If it's hunting up and down at idle it's probably running lean, perhaps due to an air leak at the carb from the leaky gasket.
singingpig ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 487 |
Using it only for cultivating, I used to get 8 hours on 5 gallons of gas.
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
If your gas is dripping when you turn it off, it is also overloading the engine when it's running. I will not idle correctly if the carb is flooding.
Take the carb off and turn upside down and blow into the fuel line. Then turn it right side up and blow again. You could have a speck of dirt under the valve that might blow out. Open the drain at the bottom of the bend on the air tube to see if it has gas in it. Usually if the carb floods it goes into the tube.
Bob
