G lift pin thingys
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: G lift pin thingys
    Posted: 07 May 2010 at 9:03am
Last winter I finally found a master tool carrier for my G, gave the required pint(s) of blood.
The joints are free and pretty tight, but I am missing the lift links / springs.
I was thinking I could just hook the cultivator to the lift frame with some chain, wouldn't the down pressure on the sweeps keep it tight?  And still allow it to come up if I hit something?
cheers,
Creek
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 12:07pm
Creek,  First congratulations on obtaining a tool carrier for your G.  I'm sure they are tough to find.
Could you use it without the required pressure rods?  Of course, but it would be better to use the proper links.  You do need some solid pressure to operate the cultivators or they may not penetrate the ground.  Check with Sandy Lake they may be able to find you what you need.
Good Luck!
Bill Long
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 12:41pm
CJ, those are not difficult to fabricate.  If you don't find some, I am making a mental note (90% mental, 10% note) to take pictures and measurements of mine.  We are going to the farm tonight.  No computer there.  You have a 50/50 chance I will remember to return with the camera.     Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 1:46pm
Thanks for your comments.  Bill - you are probably right, I would just be depending on the dirt being loose enough to pull the cultivators down, there is a good chance they would "bounce" off.  Dave - that would be really great,  I'm able to get stuff fabricated here at work by a really understanding metal fab dept (I just had a featherplate cut for my whiz bang chicken plucker, all it cost me was a box of donuts and a Komatsu hat).  If you have some dimensions that would be great.  I think the rear cultivator uses the same link.  Haven't been able to find any other AC implements that use this rod.
cheers,
Creek
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 4:25pm
Creek, can you find a picture of what you need? I might have it in my pile of "G" stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:08pm
Lonnie -
It's called a pressure rod on page 9 of the implement manual (thanks again Joe for those manuals).  I found this pic of a grader blade on a G, they were using the pressure rods to raise/lower it.  Let me know if you have any to spare!
thanks,
Creek
Edited by Creek Jenkins - 07 May 2010 at 5:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2010 at 5:18pm
I have 2 extras of those I could probably part with. How far north are you from me?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 8:19am
Lonnie -
That would be really great.  I'm from the Legendary Promised Land, North of Nashwauk......which today is covered in an inch or two of fresh snow!
I'll email you.
cheers,
Creek
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 9:53am
It looks like it's used on the Hydraulic Master Tool Carrier and Drawbars, part #s
Qty.
 2      800606  pressure rod
         which includes
          Qty.
            2       900938   cotter pin
            1       911442   cotter pin
            2       912018   plain washer
2        302802   spring, pressure rod
I think I've got them, NOT for sale. If you need I can measure them.
Where did you find that scraper blade. I will trade my set of lift link/springs for a scrapper blade.     :>)
Dusty
Edited by Dusty MI - 09 May 2010 at 3:35pm
jimwithag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimwithag Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 3:14pm
I'm interested in one if u still theml  Mine is about 12 inches long, and has an L hook on 1 end - jimwithag@aol.com. Thanks
Jim Cridge
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2010 at 8:38am
Dusty -
Unfortunately, not my scraper blade.  I think that is a pic from last summers G roundup, I believe Joe took it.  I saved it 'cause one of these days I'm going to try to build one.  Maybe I'll build two.......
cheers,
Cree,
This page was generated in 0.045 seconds.
