G hood
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: G hood
    Posted: 02 Apr 2011 at 11:47am
I's always been somewhat of a pain to reach up under the hood on my G to hold the 5/16" nuts while turning the bolts from the top with a large screw driver.
So I spent most of yesterday designing, making a pattern, and producing a pair of straps to replace those nuts.
I was pleased enough with the outcome that today I made another pair.
If anyone has the hood off their G and will be putting it back on in the next few days, would like to try these, for the cost of shipping I will send this second pair.
Dusty
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2011 at 12:20pm
I got tired of it too! I installed rivet nuts in mine several years ago
http://www.rivetnuttool.com/
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 7:54am
Joe, I like the river nut idea. I have a kit, the tool and some different sizes of rivet nuts. I thought of using it but if I remember right the largest is 10-32, which I've used up, and didn't know there are larger ones.
Looking at the spec. charts you would have to us the 1/4-20, or have to drill the base/end piece out to 1/2" in order to use the original 5/16" bolts.
And I sure would use some anti-seize. A little rust and I would think those rivet nuts would spin. Then how do you get them out?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 8:48am
Dusty, you can get them up pretty big, I went with 1/4-20 a stainless bolt and a small polished stainless flat washer. I do keep anti-seize on them and just snug them down. I had one come loose once, you just have to carefully grind the head off.
Ford 345C TLB
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2011 at 9:35am
I riveted 1/4" nut plates on mine.
