Front wheel weight ?
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Topic: Front wheel weight ?
    Posted: 08 Apr 2010 at 10:01am
My cousin called me from an auction this morning and said there was a pair of front wheel weights with the number AM 3684-1.  I asked him to bid on them for me and now I am the proud owner.  Could someone tell me what they should fit?  Thanks.  Tom
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 10:31am
Those are for the 16" wheels WC, WD, WD45, D17. They weigh about 90# each. hope this helps.
Have a good one Bill P
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 12:20pm
Thanks Bill, I was hoping that was what they were.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 12:50pm
I have a set of them also, I bought them with a set of rear weights.  Im just kinda curious how do they mount? Do they bolt to the slots in the edge of the rim? Are they hard to come by? What are they worth?
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 1:43pm
Dan,
There is a special square-headed bolt to hold them to the rim.  The head looks normal, but is offset to one side so it fits against the rim.  You can also make a functional one yourself by grinding away one edge of a hex, carriage or square-headed bolt.
The weights used to be common as they were used on some Gleaner combines.  However, most of those old Gleaners have gone to scrap and no-one saved the weights!  Generally the ones I've seen for sale have sold in the range of $75-150 per SET.  I paid a tractor salvage yard $90 for my set (without bolts).
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 1:52pm
Thanks Russ, I gave $75 for my set with the rears too so i dont think i did too bad. I also have a wider set of weights that are on a Gleaner "F". Il try and look at them a little closer maybe get some #s off them. If i recall they mount a little different but i could be wrong.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2010 at 7:30pm
Hey Dan 7080, I had an old bolt I copied. Took a square head 1/2" bolt and ground one of the flat sides down to the shank, worked just fine. I think it was 3 1/2" or 4" long.
 have a good one BILL P
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 1:13am
Thanks Bill. I looked at my other set today they have the markings ROWE FDRY across from one another and 10 and 1980 across from one another they have 2 different 4 bolt mounting holes and are on 7.50-16 tires. They are on the back of a '73 gleaner "F". Any ideas????
This page was generated in 0.211 seconds.
