FP50-24 Forklift Carburetor
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Topic: FP50-24 Forklift Carburetor
    Posted: 06 May 2022 at 6:36am
Want to convert my originally gasoline powered forklift from lpg back to gasoline. Does anyone have or can recommend a carburetor that would work properly? I don’t use this machine much and right now it needs the supply hoses replaced. I’m not happy with the lpg conversion as it is a propane hog and lacking in power. It is an old universal lpg conversion that I can’t even find the name of. I did find information on how to adjust a similar system and have it set up as good as it is going to get. The engine compression is good and it is tuned properly. Does anyone have a suggestion?
Edited by cmsmoke - 06 May 2022 at 6:38am
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 8:58am
your tractor should have a G153 motor .........
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 9:05am
G153  is a 'Buda' engine, same as in Cockshut30 farm tractors, might be an optional source for a carb ?
My forklift has the BD153 in it (diesel) and I bought comlete running '30' with the intent to replace the 'ultra low compression' diesel with gas. it was going to be a long , 'slugfest' ordeal so I passed..
Yikes $400 for JUST a carb ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 4:48pm
The one I would need is $480…Lol! I want to find a used one.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 6:18pm
I want to do the same thing to mine.  I would gladly pay 480 for a new if it had the right throttle linkage on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 7:26pm
the "14991" listed for the "OLD 153" does not seem right ($480) ... That same carb fits the 226 and 230 inch motors ??? That cant be right. ........... i would call and ask whey the 12566 would not work ($380.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 8:26pm
I won't pay almost $500 for any single barrel carburetor. If I used this everyday, it would be a different story, but sometimes it will sit for a couple months.
I'm looking for a used one in the 153 cubic inch range that has an adjustable main jet that is horizontal, has the right bolt centers and has the linkage on the correct side. I found several candidates this afternoon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 9:01pm
Tony, i did the same thing several months ago... I have bought China carburetors for chainsaws and gocart engines that worked fine.... Figured they MIGHT do OK on larger carbs ???..... I was considering changing the carb on a CASE Backhoe of 159 cubic inch engine... Looked on e-bay and found a couple "china" version for old IH or FORD tractors in the 160 CID range........never did pursue past LOOKING.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 10:50pm
Same here with the small engines. I hate to buy china, but no customer complaints. I have no problem modifying a carb to work. An adjustable main will make it easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 11:00pm
i have noticed there are about 3-4 main "sizes" of carburetors... Like a "B" will not fit a "WD45" manifold... Bolt pattern and throat diameter are different... Might have one size SMALL that goes on  motors up to 150 CID.... a MEDIUM might fit 140 - 200 cid... a LARGE might be over 200 cid ... etc.... Obviously a "MEDIUM" body that fits a 140 cid or a 200 cid engnine will need different JETS inside... but the BODY is the same SIZE... get that right, bolt up pattern and throat diameter.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 7:44pm
It could also use a Marvel Schebler TSX670, TSX701, TSX815 TSX844 from a D15
