Found a B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:07am
mooboy, your thinking right on the price. the small 3/4 inch bore cylinder is stock. It was used to lift a plow or cultivator ont he back. normally there is a "rock shaft" which is a 1-1/4 diameter solid steel bar mounted from fender brace to fender brace behind the seat. That shaft has 2-3 different crank arms on it that bolt to the plow/ cultivater, and one arm that the cylinder pushes onto. IT s small but has quite a bit of lift due to being 3200 psi system. Not a bad little tractor, but i dont like the C wide rear personally so its worth less to me from that point.
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 8:18am
Mooboy, All I ask is that you let us know what you decide to do. If you decide to dicker with the dealer, let us know how you make out. Then, if you get it, keep us posted on how you progress.   I agree with the most recent suggestions on value. By now, you have found out how much help can be found here. Never hesitate to ask for some.
Bob@allisdowneast
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 10:38am
Looks like a diamond in the rough but no more than 200 dollars!
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 12:21pm
I'm in the $200- $250 range. I'd take cash in the form of $20's and stick it under their nose. Fanned out, it looks better than a check book. Cash always seems to talk louder than anything else. I like to see them saved from being junked, even if it is a combination...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2010 at 5:46pm
I'm wit' Bri on dat' one. Save it, even though its a little "mixed up"! A Duece should take that puppy home. Fan out 10 $20. dollar bills like Brian said. Money talks....
Steve@B&B
