How do I Loosen TRACKS on HD91965 |
BillRO
Bronze Level Joined: 10 Sep 2014 Location: Albertville, AL Points: 18 |
Posted: 15 Sep 2014 at 6:18pm |
How do I Loosen the TRACKS on a 1965 HD9B, Thank you for your help
Edited by BillRO - 16 Sep 2014 at 1:30am |
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4370 |
The big rod pushing the idler ahead on the track frame is threaded on the back .The front has a hex to let a wrench get a bit on it.Most likely will have pipe wrench marks behind the hex.The HD5 of the same age have a trapezoid shaped nut that has 2 bolts that pull the nut back locking the shaft from turning with vibration. I don't remember if the HD9 has the same lock or not but there is a lock somewhere.Good luck as a place where things rust and if not turned in 20 years may take a lot of lose juice and a big pipe on your wrench.
BillRO
Thank you , This has got to be the Worst Design of any
Ray54
All brands used the same system ,and all changed to the hydraulic style at about the same time.The hydraulic adjusters have there problems as well.
