7000 series pulling tractor |
super allis
Bronze Level Joined: 21 Mar 2013 Location: Effingham IL Points: 4 |
Posted: 21 Mar 2013 at 9:12pm |
wat would be the best route for a clutch to hold up in a 7045
O.P.S. Heads
Orange Level Access Joined: 02 Jan 2013 Location: Iowa Points: 574 |
It depends completely on how much horsepower you plan on making. Need More information.
super allis
its probably pushing around 8-900 rite now not really for sure but in that ball park,, clutch hub is shearing the teeth off, puling in a 12,500 and 14,000 open class, everything stock pretty well besides the motor
ILGLEANER
Orange Level Access Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6442 |
You aint from Effingham your from Green creek.
IG
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
What have you got done to this tractor? WHat pump, injectors, turbo or turbo's? We need pics! lol Love to see it.
Orange Level Access Joined: 12 Sep 2009 Points: 19563 |
The torque limiter hub on the flywheel?? or one of the two internal Power Director hubs ??
super allis
The power director hub shears off can't slip it like you could a triple disk so it takes a lot to just get it started torque limiter is bolted solid
I'm too stupid to figure out what you are failing????????? How about the splines inside of the low range clutch housing???....I've never seen any "hub" fail as you describe it.
MACK
I would guess he is talking about the teeth on the clutch discs. MACK
