HD6G radiator
skybum1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Topic: HD6G radiator
    Posted: 09 Jul 2011 at 1:20am
Anyone know where I can find a good radiator for an old HD6G?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:38am
The radiator in this machine is in pretty bad shape.  Any body know where I can find a good used one?
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 9:44am
unless you find someone dismanteling one, you won't find one. you can get your's recored which would probably be your most efficient and longest lasting repair. i have one or two but they are not in that great of shape either, 1 i know has a pinhole and not sure of the other one. if you are looking for a spare to have recored, let me know i will see what i have for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:22am
Thanks.  The radiator shop said recoring would be my best option but also quoted about $1200 to do it.  Does this seem reasonable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2011 at 5:58pm
ow, that hurts. i would shop around a little to see if it is fair. sounds high to me although copper is very expensive now. is your old one leaking or just clogged? can you rehab that one?
acisbest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acisbest Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 10:53am
Wow, $1200 for a re-core... I had mine done in 2003 for about $400, wow copper really has increased.
I think you right track needs to be tightened  a little...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2011 at 11:21am
try Thill Track and Tractor in Eau Clare WI , got one for a HD 5 from them and was good price and perfect shape , they might have a lead also on one if they do not have one
Post Options Post Options   Thanks (0) Thanks(0)   Quote skybum1 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 11:42am
Shaefer Ent. out of Wolf Lake IL located one from Penn. and one from Ohio for $500 and $700.  I ordered the one for $500 with a 30 day warranty.  It's gotta be better than the one I had, knock on wood.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2011 at 11:54am
Mine was recored 2 years age, cost me 400.00
