Plow share ID
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: Plow share ID
    Posted: 23 May 2011 at 1:10pm
Have a very old Allis plow that I would like to find shares for it. It started out as a 3X14 pin hitch plow behind a WD. Somewhere it got converted over to a 2 bottom plow with a snap coupler. The previous owner said one of the plows was removed and a snap coupler adaptor was bolted in place of the pin hitch coupler.
The share has 3 bolts holding it on and is approx 4" wide. The back 2 holes are the same distance from the top and the front hole is a little lower.
Polished the back of the blade with an angle frinder and paint stripper wheel and could only see what appears to be an "H".
Thanks for any help that will allow me to obtain new shares for it.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 3:00pm
If it would happen to be the same as this one, I can still get the numbers off of it... http://allischalmers.com/new/forum/forum_posts.asp?TID=26363
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 4:17pm
Murph
Yours does not appear to be the one I need. Photo of mine below:
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 4:46pm
The Weise link shown on this forum last week shows share dimensions. My AC plow bottoms book does not.
I'd think plow frogs would drill a lot easier than plow shares that could be hardened.
Have you a picture of the plow assembly from the bottom? I might be able to match up that picture with the illustrations in the plow bottoms book to get a range of share numbers.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:40am
Gerald
Could not locate the Weise link, can you locate it for me?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 12:16pm
http://www.wieseindustries.com/to-fit-allis-chalmers-plows-387-390-series_p_-1,79,219.cfm
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:13am
Thanks Gerald
It appears that Weiss's 14" share has 4 mounting holes; mine has 3 holes. Will contact them to see if they can help locate the share I want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 10:00am
Use three holes that fit, plug the fourth with a bolt and nut or drill the frog to pass the fourth one.
On some plow shares the fourth bolt away from the nose of the plow bolted to a flat steel strap that bolted to the frog or to the moldboard when the frog was short.
Gerald J.
This page was generated in 0.128 seconds.
