1952 WD oil bath air cleaner
Mikey Joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Joe Quote  Post ReplyReply Direct Link To This Post Topic: 1952 WD oil bath air cleaner
    Posted: 25 Mar 2023 at 10:10am
I have thoroughly cleaned the inside (including the mesh screen and the outer/inner air passages) of the oil bath air cleaner. Some how oil is being pulled into the carburater. I only filled the bowl to the fill line with 10W-30 engine oil. Why is this happening is happening?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 4:48pm
Use SAE 30 wt and make sure you are not over filling it. Stay below the line. The 10w-30 may be too light if you haven’t over filled it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 5:14pm
Straight 30 will not bubble thru as will the 10W30
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 5:43pm
Welcome to the forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 5:55pm
i have never had a problem using 10w 30... are you SURE the inside screen is clean ? Not just the part you can see... you need to SOAK the air cleaner in a bucket of diesel / gas/ solvent ... then drain and blow out with air... If you plug up 30% of the air path, the remaining area has to pull MORE AIR thru a smaller section and the extra velocity can carry more oil thru.
Edited by steve(ill) - 25 Mar 2023 at 5:56pm
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 8:04pm
Any chance it has a WD-45 engine, or has been rebuilt with WD-45 components? Not sure if the slightly bigger displacement would cause it to suck oil in (experts on here probably know if this happens), but I think the WD air cleaner was smaller than the WD-45. Just a thought for something else to check.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 8:40pm
Probably not a bad idea, small restrictions in the air flow path could increase air velocity and vacuum.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 8:45pm
Take the wire mash out, soak it in gas then set the mash on fire. When it cools, unroll it and knock the dirt out. Next, cut top of housing off just below where it starts to taper down. Use a wire to clean dirt out between inside and outside wall. When clean bronze top back on. You won't believe how it ever ran before.
You will think the mash is going to burn up, but it won't. May have to burn it the second time  to get clean.                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2023 at 8:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 9:12am
I dissembled the air cleaner and used degreaser on the interior mesh. I then soaked and "sloshed" the entire cleaner body in a 5 gallon bucket of hot  water with Dawn. Did this several times over a couple of days. After that I sprayed degreaser in the air inlet between  the outer shell and inner liner. Finally I used a compressed air wand to blow out the interior of the shell.  Did a final soak/rinse with hot water and Dawn. This time the liquid was clear coming out of the air cleaner shell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey Joe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 9:14am
Engine straight WD except for manifold. It is from a D-17.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 9:20am
I'm going to do this for the Narrow Front 45. Have an extra one in the parts vault, just get it ready then swap it out. I did the first half to the one in the wide front when I put the power steering on. Wasn't aware of there being a second half! It blew my mind how much 'stuff' came off the mesh when I burned it!
I suppose once I get the NF done I could do the one that comes off and put it on the WF. Here I told myself I was going to try to slow down on the projects this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2023 at 9:31am
Mikey, if you want to run a TEST, pull the rubber hose off to the carb and run the tractor for 30 minutes and see if it runs different..  or take the oil bowl off the air cleaner and run it that way... of course your not going to get any oil in the carb during this test, but you might see a difference in throttle response or power ?
