wd45 cooling problems |
Post Reply | Page <123> |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8009 |
I'll tell you like my 17 yr old grand son....measure the length of old hoses BEFORE taking apart and pay attention to how they fit on the ends lengthwise. The rad hoses are just straight hose. The bypass hose can be bought at auto supply as a trim to fit 90. Probably all available from AGCO but maybe cheaper from NAPA.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4410 |
That used to be true in our area, but NAPA has gone absolutely crazy on prices around here. I like NAPA's stuff, but I have found that I can buy most stuff from a dealer cheaper than NAPA.
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 434 |
is the bypass hose the hose that goes from the thermostat housing to the water pump
hunter321
i have to get a new radiator. what do i do with the old one
Around here it goes to the scrap metal yard/recycle place. They weigh it and pay you .
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77852 |
a bypass hose is normally a bout 3/4 inch diameter... and goes around the thermostat.
hunter321
i know this off topic but i need to know where i can get the bracket that the carb float attatches to. i am going to ahve a shop replace it but i need the part
is this right. the carb is a tsx 561 should i get a quote on how much it would cost the shop to do it all
Edited by hunter321 - 14 Apr 2023 at 2:29pm |
Orange Level Access Joined: 12 Sep 2009 Points: 19554 |
That particular carb part was NEVER available from AC some 50 or more years ago. Roberts should know that !! Call Bill Deppe in Maquoketa and get a used carb or he probably has one ready to go.
hunter321
So my carburetor is junk
I wouldn't waste my time. Use it for any good parts it might have. Get a different carb.
hunter321
Ok I will try to get a new one from bills in n maqukata
Maybe he can fix it |
Bill Deppe will not have a "new" carb, but will probably have a used/rebuilt carb ready to go. 563-357-2615
hunter321
That's what I meant
hunter321
With the new radiator in place and a different lower radiator hose the tractor doesn't get over 120 much.
The hosr came from a different wd and had been on that tractor for at least 50 years with no damage |
hunter321
again off topic sorry.
what size socket is the wheel ecentrics not the rim stops
WF owner
3/4"
If they haven't been turned for a while, they turn very hard. I spray them for a couple days with Kroil before I even try them. I always use a 6 point socket. I have a long 3/4" drive breaker bar and two 3/4" drive 3/4" impact sockets; one regular and one deep well. I have never had this setup fail me yet. When I was a kid, I remember Dad using a 1/2" drive 3/4" socket, extension and a 1/2" breaker bar (all Craftsmen). If he couldn't turn them, he would put his Handyman jack under the breaker bar. Many times, he actually jacked the back tire off the ground. If it still didn't loosen, he would hit it with a sledgehammer. It either loosened or broke the socket, extension or breaker bar. Sears replaced a lot of them!!!
Edited by WF owner - 21 Apr 2023 at 11:28am |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50559 |
If they have been marinating in calcium chloride for years, they may need more drastic treatment...
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
A good video but I do not reuse lock washers. Once flattened they loose their lock the next time. Found that out on a Onan engine after I replaced the sump gasket. Had to pull the engine again to replace the lock washers after the engine vibrated loose and began leaking oil. No issue after replacing them.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3461 |
hunter321
What would happen if I put the wrong carburetor on a tractor.
For example a Ford carburetor on ona wd45 |
hunter321
if i had a carburetor that fit the tractor but was not the correct one would it work
hunter321
how does the rod with thegreen arrow pointing at it attach to the tractor. one of mine is broken.
Find the picture of the brake shoes....you'll see the part it screws into
hunter321
Can you mark the connection point |
bottom right ....it's called a toggle pin. That rod screws into it . They get rusty and twist off if forced to turn. Once everything is set up in correct position/clearance with the brake shoes, that rod never needs adjusted again. Brake adjustment is done through top covers on rear housing.
Edited by SteveM C/IL - 05 May 2023 at 8:29am |
An attempt to answer the carburetor question: A carburetor is spec'd and configured to fit and work properly on a specific engine. It is designed to start well at almost any temperature. It is designed to allow the engine to operate from 400 RPM idle speed up to the maximum speed the engineers designed the engine for. It is designed to produce a specific HP and fuel consumpion at a specific engine speed. I can't imagine what you're trying to do, but you'll save yourself a lot of time and $$$$ by just using what carb the tractor/engine was designed for.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3296 |
get the right carb because nothing will not hook up right and like the dr says it just will not run or operate well
hunter321
how exactly do i acces the brake rod toggel bolt so i can replace the rod and remove the broken part from the toggel pin
I doubt you can heat it and get ahold of it with vise grips but to unscrew broken piece that way would be GREAT!! Next you get to learn about the dreaded bottom brake pin removal.
Sometimes they come out without too much trouble but usually you get to use a cutting torch. GOOD LUCK!!
hunter321
Thanks
How do I get to the bolt so I can remove it Is the brake rod on a wd the same as a wd45 |
