D-19 gas 262 vs. gas 262 from combine
only AC orange View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: D-19 gas 262 vs. gas 262 from combine
    Posted: 11 Nov 2022 at 8:45pm
I recently bought a D-19 with transplanted 262 combine engine. Governors were not changed at time of replacement, Should they be changed before doing any work or play with it? What is the hspwr. rating of combine engine vs. tractor engine? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2022 at 6:51am
There should be an engine ID tag riveted to the block. It might say G-262 or it might say G-230. To most people they look EXACTLY the same, because they really are except bore and stroke and the carburetor. Even at that, a later model (1967 ?) G-262 has a larger carb on it (Bendix) than older engines (Marvel) and has more power too. If the carb size is the same as a D-19, it will yield the same HP at the same RPM as a D-19 tractor engine. A combine governor has a control cable that directly connects to the throttle butterfly shaft on the carb. A tractor governor has linkage that goes down the left side of the engine to the top of the governor area and controls coil spring tension on the governor arm. So, what do you have ??   I cannot imagine running a combine governor set-up on a tractor.  The governor only works at 100% FULL throttle.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2022 at 6:57am
Thanks Doc., don't know what I have. Will look at and determine later today based on your info.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2022 at 10:30am
G-262 with Bendix carb and linkage down left side of block to governor housing! Thanks again Doc!
