Concrete ??
 Post Reply Post Reply Page  <123>
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 6:30pm
You could always do a 10% testing regime.  Like me with sending out puns, I sent 10 puns to a friend to see if I could make him laugh...  no pun in ten did...Wink
Edited by DiyDave - 06 Jun 2022 at 6:30pm
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 7:16pm
Too much dry air tends to eggcelerate the drying time.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 7:30pm
Eggcellerate?  You're in the wrong thread.... that goes in the Chicken topic...
(but it's a good yolk... you should white them more often...)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 7:40pm
Gotta crack one every now and then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 7:47pm
Originally posted by Kenny L. Kenny L. wrote:
 Dave, didn't you also have to do a air test every sample, I know the company I work for did but I can't remember if it was mandatory or not, the supervisor we had always had us over sampling everything just to be sure are asses where cover.
 Also how do you like doing the daily report for the project? I thought it was a lot of wasted time and a pain the ass.
Fortunately, Kenny, I am not the guy that has to do formal tests, the people strapped to that duty are who I go to to pull records when there's a developing problem.  I do my slump and cylinders for my own projects, for my own reference, and the person who determines those requirements, and answers to any failures, is just me Wink  but yes, air-entrainment is a concern... like admixtures, application of air entrainment is critical to making certain concrete pours survive freeze-thaw... but to get an accurate measurement in a fresh batch, it really takes a pressure-vessel test, and that's not something I happen to have lying around.  I've got several microscopes, so I can cut a piece after-the-fact, and look at a cross-section, but by that time, it's too late.
The reports will be a PITA in many ways, but no worse than any other production under 100% quality assurance through statistical process control.
Most people don't 'get' the difference between 'quality control', and 'quality assurance'.
Quality control is when you use output data of a process, to control the input and process, to provide a production result that is not only the most consistent, but having the lowest failure rate.
Quality assurance, is when you check EACH component, and remove any components that failed, so that no matter WHAT goes out, the  ONLY thing going out, is 100% good.  While you're at it, take all the failed ones, send them back for forensic analysis, find out WHY they failed, follow it back to the Root Cause, and FIX THAT, so the Quality Control number improves.
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2022 at 10:06pm
 I definitely know what you're talking about I was in the game for 27 years and was certified in Agg 1&2 concrete 1&2 and asphalt 1&2 about the only thing I couldn't do was job mixes but help on a lot of them, I done most of the proportionate material for concrete and asphalt yes I run a lot of sample each year, I covered from just out side of Mechanicsville to Montour just east of Marshalltown, had all of the Cedar Rapids area including the quarry on the north side of Robins and the one just west of Springville ,one up by Coggon, also one out by Vinton and one by Garrinson and one we call 4 county just south of the CR airport and three sand pits, The sand pit were just spot check because the plant man was certified also. I would also did a lot of asphalt testing when they were running out of Moscow quarry which is west of Wilton on 6. I remember when doing concrete or asphalt testing the day were long and on the go all the time and the guys that done the daily reports would still be their when I was walking out the door after getting all the test equipment clean up and the lab for the next day some day were 14 hrs and some long if I had to help cut cords in the mornings. I didn't do concrete test all that often just when someone need of or sick. I know with concrete you had to be around it to be good at it, I had to almost carry the book around with me. Thanks for letting rumbling on.
maresand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maresand Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 1:16pm
Sometimes I love reading topics like this one—people who ask stupid questions never stop doing that. You never thought about asking the concrete company about that? Sometimes they cannot make it because of issues with the concrete or the type of concrete work they are doing. When one concrete company was doing some siding job at my summer house, it took 2 days to fill the necessary space with concrete. When I asked them why they didn't do this in one day, they answered that if they did that, it would be possible for concrete to be unstable during the incoming rains.
Edited by maresand - 11 Jul 2022 at 2:35am
firutaarnold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firutaarnold Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 9:35am
I've heard stories many times that people poured concrete of different colors, although the interval between fills was no more than two hours. It can greatly spoil the appearance of someone's yard or garden. To my friend, the contractors made a terrible path in his cherry orchard. I never turn to migrant workers who don't have certificates that they are professional builders. At my house, the outer walls are lined with volcanic stone. I ordered Lava Rock Wall because I know it looks stylish and cool compared to other ways to decorate the house's walls. When I contacted the construction company, I found out in advance that they have all the necessary certificates. Also, you always need to ask what kind of guarantee builders and contractors give, guys.
Edited by firutaarnold - 05 Aug 2022 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 5:28pm
I'd expect to see a greenish tint after some time when used in or near water = dam wall, and sich.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 5:56pm
Someone forgot to ask the company to batch all the ingredients from the same barge or rail car and to make sure it all came from the same kiln and from the same quarry and same depth .
  Now if someone had been smart they would have added a color to the job order and poured it all the same tint .
  It might have been bleach could have been needed or if the calcium chloride used to speed setting was from different batches .
  You know one way it could have been solved is to add 100 pounds of SUGAR to each truckload . The results would be superb in getting all the pours equal ....
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 6:01pm
Sugar?  or  Equal in the blue packets?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 6:10pm
I keep wondering about what one does with all the information one collects after asking a question .
 Part of my building inspection Degree was a class on concrete and those credits were something I remember as part of the final was a presentation on Concrete .
  I did a report on new bridges built in So St Paul MN across Mississippi River using post  tension sectional poured modules where each pier was built out to meet the other piers .
  Was last presentation of class and after the Professor asked me if he could keep all my slides and information to be used for future classes as no one else had ever did research or information on that type of construction.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2022 at 7:06pm
We bought a house/home that built in 2094, it has a poured wall for the foundation/basement walls, it's all concrete gray.
 Dusty
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 12:24am
Kenny,
did you ever use a NCAT?   I did a lot of repairs on those.
I am still confident of this;
Wait for the Lord;
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 6:56am
 Dusty
2094, wow!  What's it like then?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 7:36am
Local concrete company where I grew up used to throw two 50# sacks of Sugar in each truck, should the truck break down and the Pony driven mixer still be running to keep the batch from setting the drivers were instructed mix the sugar in the mix.  Would still set up but SOFT, could darn near to remove from the old mixers(7 or 8 yard) with a shovel.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 7:37am
Built in 2094 !
Was it built on the Moon or some other Terrestrial Planet ?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 8:05am
I heard George Jetson was born on Sunday, so.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 8:55am
My mistake guys. 1994.
 Have a good time.
 Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 9:08am
 Have a good time.
 Dusty
Didn't mean to pick on ya' Dusty, it's all good.  Try not to pick apart typo's much, but that was a funny one!
Hope all is well with you.  I never did get to stop by on the way to K'zoo..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 3:27pm
Kenny,
Lew I can't remember the name on the test equipment, I'm lucky if I can remember yesterday, the only thing golden about old age is your pee.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 6:09pm
What the heck happened to the original poster of this, ole Freebie?  He seems to have gone radio silent...
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 7:34pm
He ran out of stupid questions to ask ??? ................ NAH ! Wink
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2022 at 8:10pm
We ain’t seen hide nor hair of Free base for some time.
Maybe the wife took his toy away from him.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 6:54am
His old Ford finally ate him
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 8:32am
He got stopped at the train tracks of one of them REALLY REALLY LONG TRAINS... Been setting there for 5 weeks !  Wink
Hope he had a fish sammich with him .
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 11:06am
Perhaps he grabbed the wrong bottle, drank the blue fluid and poured the brown bottle in the oval and too ashamed to admit it. Sounds fishy to me
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 5:02pm
I think he is moving to Washington... I heard Biden gave him a job as the Head of the Dept of Healthy Fast Food specializing in Hamburgers and Chocolate Shakes.. Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 5:24pm
Fart czar?  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2022 at 7:57pm
I gotta admit, he was entertaining. Did he pizz off the Mod?
