H3 pto |
elec
Bronze Level Joined: 23 Nov 2020 Location: mi Points: 84 |
Posted: 28 Sep 2021 at 6:35pm |
I have an H3 with a pto. Was told that in d15 with shuttle the pto is not the right speed. My h3 dozer has a shuttle, so does the pto run at the right speed (540)? Would like to run a pull type brush hog with it.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50559 |
Rev it up and put a tach on the pto shaft..
Beam
Bronze Level Joined: 26 Sep 2021 Location: South Bama Points: 19 |
The manual states it will run at 540 at around 1650 rpm (I don’t have access to it now to get exact RPM) regardless of gear. I’m going to add the tach on mine in order to ensure mine runs at 540.
1962 H3, WD45, B210
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 900 |
I borrowed a H3 with a pto and I used a 6' bush hog type mower with it with no problems. I also had a H3 LB and with no pto. I installed a hydraulic motor on the bush hog and used the hydraulics for the backhoe to drive it and it worked well also.
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
H-3 PTO has a gear box at the rear which corrects the PTO to standard 540 when equipped with the shuttle. D-15, I-60/600/615 does not so has non standard PTO speeds
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9106 |
This is what's on my HD 3 , let's say if a guy had a extra unit what would a good working PTO Unit be worth .
