D14 Final drive spacer
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: D14 Final drive spacer
    Posted: 24 May 2021 at 5:41am
Bought a D14 last fall and didn't notice until recently that it had spacers on the final drives.  I looked this up in the online Agco Parts book and it does show them.
It says they are for 63" to 97" wheel tread.
I've never seen these, does anyone know what implement they would be used for and
how common are they?
D15D, D17G, 170G, 175D, and two 5050FWA
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 12:16pm
Here is a set I will be installing on a D-15 series 2 diesel along with a single front wheel  for a forum member that I am rebuilding  tractor for.  ,he can jump in and fill u in on what he's doing it for.
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 12:36pm
Fred, is there an extension for the top shaft, or is it one complete DIFFERENT part from the standard D15 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 1:52pm
Top shaft Is longer
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2021 at 2:17pm
I was also wondering about the pinion shaft . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 5:53am
Were these used if you wanted a mounted corn picker?
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 10:30am
They were used on the high crops D 14 and 15.
How wide are the spacers?
Edited by Richardmo - 25 May 2021 at 10:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 12:29pm
The spacers are 4-5/16" wide.
The reason I thought they might be for a mounted corn picker is because is has what looks to be a factor screen enclosure on the air intake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 2:48pm
6 1/2  on the axle's I am working on
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 4:14pm
In your AGCO book..do the spacers imply a high-crop or a single front end????I would bet on the corn picker or vegetables....Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 7:43pm
The high crops have the wider one.
Also check the parts book calls out for a different axle for the picker so maybe that is what that is for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 3:34pm
Found my own D-15 book ....appears there were also 3 widths of wide front ends....did not list applications of the wider rear....Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:14am
Here is some info from the online book. They have different part numbers for pinion shafts but only one part number for a RH and LH side spacer.
