Off brand, jd 7000 planter question
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Topic: Off brand, jd 7000 planter question
    Posted: 12 Apr 2021 at 5:05pm
Wrong color I know but I need to remove the side markers from my jd 7000 4 row wide planter. I can't find in the manual how to go about this, any suggestions or tricks to make it easier? Thanks
1955 WD-45 with factory PS
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:13pm
Google  "Removing JD marker arms on a 7000 planter". A 3 part video came up Approve .
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:38pm
Holy [IMG]uploads/1/censored.bmp">, freedguy googled something???
But....a three part video? What the heck, it ain’t that complicated.
So, you say taking off the markers, are you replacing, repair and replace, not using anymore at all? That can affect whether you are taking out the lifting and row switching cables and valve.
But to take off just the markers, take the pin out of the clevis on the cable, then take the pin out of the breakaway hinge and it comes right off. We store ours in a low shed and take them off every year. How many rows? There’s a few more pieces on 8 rows and up.
Edited by Tbone95 - 12 Apr 2021 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 6:57pm
I could also read that it's a 4 row in his original post WinkWink
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 7:47pm
Mice think the toolbar on my 7100 makes an excellent condo. I do it slightly different than Tbone but his way would work fine.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 9:19pm
We bought a JD 7000 6 row pull type planter with the "Kinze" units last year. We made it a 6 row 3 pt replant planter. So the markers, hitch, drive wheels had to go. The markers, I took out with a torch, lines and all. What a complicated setup for markers.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 9:49pm
i'd say a torch too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 9:50pm
WAIT....gosh...where's my mind at....should be "tannerite"! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 10:42pm
Thanks for the fast replies. I'm storing it in a low shed is the reason for removal. They need to be in the "lowered position" to be removed correct? I just don't want to mess up the cable system for the markers. I will check for the 3 part video as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 7:01am
The actual marker arms come pretty simple, if I remember right. Pull a pin and a couple of bolts and the rest of the assembly stays put inside the frame.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 7:09am
Yeah...phone screen, no glasses, I did OK.  But good for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 7:13am
If you pull the clevis pin from the cable, you don't have to lower it with hydraulics, just set the marker on the ground.  Although, if adjusted to pull up tight, that may not come out very easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 7:19am
Leon B MO
Complicated setup for markers.....well, maybe so, IDK, never had much issues with it working incorrectly. The JD 7000 is an incredibly well respected planter.  I had an Allis planter before we bought our 7000 4 row (now have a 7000 8 row).  The Allis planter was cheap and chincy and flimsy all the way around compared to the JD.  But I know, JD is the antichrist! Wink
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 11:03am
If I remember right, Dad's 7000 markers could be folded forward for storage. And I agree the marker system is complicated and hopefully you will never have the cable break. That is a pain to replace and we replaced several over the years on Dad's.
Wink
I am a Russian Bot
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 11:08am
I had one for years but as i recall the markers weren't that hard to lower.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 11:23am
The complicated part, going by memory, was replacing that stupid cable that would fray and break.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2021 at 5:36pm
I concur with TBONE on this one, how much simpler could the marker system be on a planter  (yes we run/ran a 7000 Wink ) ?? Frayed cables seem like maintenance issue ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2021 at 12:59am
Thanks for all the replies guys! Love this website! Been working some crazy hours but should have a chance to tear into it tomorrow, IL let you guys know how it goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2021 at 8:36am
Been using a 7000 since the mid 80's first the 4 and now the 8.  We've never broken a cable, and they still look fine, so.....IDK?
The 4 row had an oil leak in the switching valve, so I've pulled it out of that one once, and the 8 row was giving me fits the first year I got it not wanting to switch, which I believe was an air bubble I got bled out, so I've pulled that one once.  Even that isn't that bad?  I couldn't recite the steps here.....but seems a couple of bolts.  I tied baler twine to it to the opposite side so when I pulled it out, I could pull the twine to pull it back in the other way.  I guess I didn't know it was that miserable at the time, apparently I was mistaken! Hahaha
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2021 at 6:59pm
That's EXACTLY what was our ONLY ailment with the 7000 Consertill  that we possess, leaky marker cylinder and the twine/string tying to put things back together, easy/peazy Wink !!! ours is an '86 model year machine
Edited by FREEDGUY - 14 Apr 2021 at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 8:58am
I was going to add pictures but can't seem to figure out how. I took off 2 bolts on outside of marker. Removed a bolt from the 90 degree "marker rod holder?" And that allowed it to lower and swing back for storage. Ow and also looses the transport holder on back of marker arm. Thanks for the help, it's my first planter so this won't b the last question I'm sure lol. Says my picture size is too large, I tried lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 9:23am
