WD45 Hydraulic Lift Arm Schematic
lshaver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lshaver Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulic Lift Arm Schematic
    Posted: 06 Sep 2010 at 9:51am
Hi All I am a total newbie that just purchased my first tractor a 1953 AC WD45. it came with a factory loader but I will want run a bush hog some day. First of all the hydraulic lines are disconnected from the snap coupling lift arm cylinders. I am not sure how to connect the cylinders to the manifold. There id currently on 1/2" line coming off of the left side if the block port 1 that is capped on the other left side port there is a hose with a quick connect coupler that is dangling so I am not sure how to connect to cylinders to the manifold block.
Also I am looking for a good 3-point conversion kit to convert the snap coupler to a standard 3-point hitch.Can anybody let me know where I can find a good one that is from a company that will ship to Canada, I am not able to find any Canadian Dealers. I live in Niagara Falls Ontario which is right next to the border. Thank you very much in adfvance for helping out a total newbie.Larry
