D 15 engine removal
 Rating: Topic Rating: 1 Votes, Average 1.00  Topic Search Topic Search  Topic Options Topic Options
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2020 at 9:15pm
And those pictures will help get #1 back together properly!!
WC, CA, D14, WD45
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 3:48am
Thanks Jay and Dave . I'm trying to take a couple pics of everything . Cell phone is a pretty good helper .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 5:42am
pix are great just be SURE to copy/backup  to a PC or flashdrive.
Wife's iphone recently had swimming leasons in the white, round swimmin hole...PU !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2020 at 6:09am
That ain't good Jay .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 6:41am
Have my engine upside down on the engine stand . Sure makes it easy to pull the oil pan . Rear main seal is very hard . Probably why it was leaking at high rpm . Anyone know where I can get a speedi sleeve for the crankshaft ? Thanks
WeisAC2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 7:43am
wow that's a pretty oil pan. When you find the sleeve, you can 'practise' on 'Troy' here...lol.
I just add oil 'as required'...too many minor leaks for me to worry about,specially since there's a LOT less seat time now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 8:06am
Thanks Jay but I dunno . I'm hoping this will be my last "big" tractor job. Oil pan was off when I got this tractor so I hit it with a little primer before putting it back on . Crankshaft looks ok to me but if I can get a speedi sleeve I'd sure use it . Thanks for looking
Edited by ACinSC - 31 Jul 2020 at 8:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 8:20am
My book says to apply a little lubriplate to the new rear main seal . Should I get some or will wheel bearing grease do ? Thanks
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 10:31am
I have always been a fan of lubricating seals with whatever fluid they run in. whenever a mfgr suggests something else I have to think it's due to assembly time and they don't want a dry start. whatever you use, make sure it will melt fast once the oil hits it. I would be inclined to use assembly lube mixed with oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 10:52am
Makes sense , Thanks Rusty Allis .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 2:58pm
Now that I have things kinda cleaned up I see the trans engine clutch shaft seals are leaking . Anyone changed them lately ? Looks like you remove these 4 bolts and pull cover to get to them ? Thanks !!
Edited by ACinSC - 01 Aug 2020 at 3:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 3:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 3:22pm
i 'think' there's a felt seal behind though be sure to drain tranny first.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2020 at 4:08pm
Yeah Jay according to the agco site there's 2 seals back there . Guess I'll find out . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 12:51pm
Have it apart and the seals out . Two seals 211111 C/R . Gotta add 2 seals and a gasket to my evergrowing list . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2020 at 5:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2020 at 2:53pm
Does the oil pump intake screen have steel wool looking stuff inside it like the oil bath air filter ? Sure hope that's what it is . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 10:28am
Another question . Anyone familiar with the tube that runs from the base of the oil filter to the oil pump cover on the back of the engine ? Mine's leaking . Has what's left of rubber packing grommets in the connection . Guy at NAPA had never seen one . Hoping Sandy Lake has some . Thanks !! Now that I've cleaned them some I see Imperial Flex on the cap .
Edited by ACinSC - 11 Aug 2020 at 10:58am
Post Options Post Options   Thanks (0) Thanks(0)   Quote WeisAC2 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 10:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 10:59am
My fav son has posted a pic .
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 1:21pm
Those grommets come in various sizes. My 8070 has them on various lines. Should be available from AGCO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 1:38pm
Thanks Steve . Sandy lake has them .
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 4:04pm
Wonder what happened to the other pics on this post ? Thanks !!
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 2:31pm
Yeah, I was reading thru this now and some pics are gone.  Maybe they were "linked" and now the link is dead...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 2:54pm
Dunno why Gary but they've been gone . Sorry
This page was generated in 0.093 seconds.
