Allis Chalmers WD45 Diesel project
 Post Reply Post Reply Page  <1 45678>
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 10:35pm
It has less than 50 hours on a complete overhaul. It had a d17 overhaul kit put in it.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2021 at 10:59pm
Well that may be but it will still have to come apart to address the counter bores.What was done to the block when the d17 kit was put in it?Doesn't sound like the counter bores were done properly otherwise your sleeves would have stand out above the deck.
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 1:45am
Some one ruined a WD-45D
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 7:10am
I can sell you a set of fire rings that will seal it up if you have some one qualified to put them in and properly torque it down.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 7:11am
Brand new sleeves (with a crisp sharp lip on them) probably did stand up a good enough amount when installed in a worn out block counterbore. But, as soon as things were torqued down and the engine run for a time, the sleeves have now settled down into the worn counterbore ledges. Now, you have head gasket blowing problems.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 8:09am
pull it down and have the block decked and all bores cut to get +.004 on all sleeves or you are wasting your time
Edited by CAL(KS) - 03 Mar 2021 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 8:42am
Is there a way to “shim” the sleeves up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 9:05am
A shim on an old, worn and non-square counterbore is a waste of time.
ACjack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACjack Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 9:11am
I'll throw my 2 cents in here. At the plant the height of the cylinder sleeve in relation to the block was referred to as cylinder sleeve protrusion. The Doc is correct on the .003 / .005 spec above the deck surface. Simply measure from the very top of the sleeve down to the deck surface. the best tool to use is a depth micrometer.
Another thought on how to achieve this dimension other than thicker fire rings (most effective) or redecking the block is what we used on the V12 engines when we started production of that engine and that was the use of shims.
When measuring the protrusion take you readings from at lest 4 or more spots around the sleeve.
Edited by ACjack - 03 Mar 2021 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 10:21am
NO,counter bores need to be cut sharp and square and new sleeves installed!!!!Anything else is a waste of more money and your time as stated by Dr Allis. One more time, counter bores recut,new sleeves set to .004" stand out, Macks fire rings, and agco gasket torqued properly to fix the problem!!!!Can't make it any plainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 8:02pm
I got some old sleeves in the shop I should go "measure the width of step on liner. IT AIN'T MUCH!!!! As Doc says,they are so skimpy shimming would be a joke. Sorry Jack but that won't work on these.
Edited by SteveM C/IL - 03 Mar 2021 at 8:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2021 at 7:03pm
Put a oem gasket on with hylomar and it works so far so good!!! No dislikes on antifreeze.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2021 at 8:24am
Also figured out that if you put a Magnet heater on the intake Manifold it will start much better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2021 at 8:42pm
Had it running for about 2 or 3 hours and no problems.
Found a hour meter I think goes to wd45 diesel but it is 6 volt
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 9:09pm
Can you add a resistor to knock it down to 6 volt ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 9:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2021 at 9:18pm
Hooked up a Allis Chalmers 3-16 plow today and plowed half the day. Only problem I had was it barely started in the morning after a hour of being plugged in and a little starting fluid. Can’t figure out why it won’t start very good when it’s 40 degrees out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 8:07am
After all the head gasket troubles and knowing that you have a couple of sleeves not sitting up where they should be and you plow with it ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 12:32pm
Yep, it pulls really good in 2nt gear (it runs quite fast for a 45) which I think is between 5 and 8 mph. In 4th it goes between 18 and 22 mph.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2021 at 9:38pm
I think I figure out what was wrong, one pair of valve was out of adjustment. I took it apart and torque the head to 105 ft lb and adjusted/ checked all the valves. I did get it back together and started it which was a lot better. I’ll see if it will start tomorrow afternoon and see if it fixed the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2021 at 10:31pm
Here’s what I’ve been doing lately with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 10:03pm
Don’t know if this worked but thought I would try to post a video.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 10:04pm
Sorry, guess it didn’t work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2021 at 10:05pm
Edited by 55allis - 06 Apr 2021 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 10:47pm
I did some tire painting today. Got silver tire paint from Amazon.com for $8.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2021 at 11:00pm
good photo with the disc hooked bet theres no wheel slip with all that rubber
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2021 at 8:35am
LOL! This guy has got everybody scratchin' their heads......  LOL!  How did Foghorn Leghorn say it? "Nice boy, but don't listen to a word ya say"......  LOL  I've had my share of customers over the years in the electrical field do the same thing. It'll eventually come back to haunt him again. Usually things like that become "hand granades" later on when not done correctly the first time. Sorry to say but that's what happens....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 7:22pm
Well now I’m back again with another problem...
And not with the engine but the clutch...
Well as the story goes I was sickle mowing with it cause I like the speed of it and just got back from a 2 mile drive and was getting ready to go for a 5 mile drive to another farm and well I replaced a guard on the mower in the shop and went to drive it out, well it made a “thunk”,rolled out and stopped...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2022 at 10:01pm
If the PTO and hydraulic pump won't work, the foot clutch has failed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2022 at 10:53pm
I think well it is apart, I will rebuild/replace the hand clutch since I know that it doesn’t have any shims left.
Does anyone know of a place that would sell just the pads for a fair price?
Other wise I might have access to a parts Wd that’s all ready apart.
