Cracked engine block |
68mustang
Bronze Level Joined: 17 Jan 2020 Location: CT Points: 96 |
Posted: 17 Jan 2020 at 11:15am |
Allis chalmers 1939 wc bought tractor with engine block is welded , it runs perfect, it seaps coolant one area where it was welded, should I grind it down and try to re-weld, the weld looks very ugly.
Should I just look for another block assembly with crank ? |
LouSWPA
Orange Level Access Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24021 |
nothing ventured, nothing gained. the trick to welding cast is to use torches and preheat and then after welding slowly cool it down with torches, and/or wrap in old heavy blankets so it cools slowly
I am still confident of this;
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8786 |
If the block is now solid, clean and seal the weld with Belzona 1111 Super Metal.
1. Remove all traces of oil and antifreeze. 2. De-grease the surface with acetone or MEK. 3. Sweat the area with a torch. This will help bring the oils out of the pores of the metal. 4. Degrease. 5. V out the crack and roughen the surface. 6. Degrease. 7. Apply Belzona 1111 Super Metal to the area. 8. After the Belzona has cured, sand and paint.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2204 |
I put Aluma seal in one. Never leaked since. Had one with JB plastered on it, that didn't hole for long. Good cleaning before application is the key to anything holding.
Lonn
This guy doesn't know much about a WD but he seems to know his welding. Welding cast iron without preheating and no cracks. [TUBE]Yopcz-IYDyQ[/TUBE]
Edited by Lonn - 17 Jan 2020 at 1:24pm |
Wink I am a Russian Bot |
johnkc
Orange Level Joined: 22 Sep 2009 Location: KCMO Points: 714 |
yep! what Clay say's. there are many boat engines out there " fixed"{LOL] that way.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
PDehring
Bronze Level Joined: 06 Jun 2018 Location: Central MI Points: 93 |
X2 on Belzona, I fixed my M block with it and worked great. Not cheap though.
1937 M Crawler, 1963 D21, 1964 D21, 1965 D12 SIII, 1970 220, 1976 185
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50529 |
Where's the leak/welded area?
68mustang
the repair is right along the carb. and intake rubber hose , don’t know how to post pictures in this forum.
Orange Level Access Joined: 12 Sep 2009 Points: 19508 |
There have been many of those blocks successfully repaired by drilling 1/4" holes in the block on both sides of the crack and threading the 1/4" holes and mounting a 3/16" flat plate to the side of the block with a gasket and plenty of RTV or Permatex glue in-between. It adds strength to the cracked area and works better than welding. Looks bad ?? Well, how good does a bunch of weld look that seeps coolant all the time ??
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
DR; your wright on the patch' works very well' fixed one the same way' i put some JB; with a gasket' still never leaked been 10 years on WC.
Dave(inMA)
Orange Level Joined: 12 Sep 2009 Location: Grafton, MA Points: 2395 |
My C was declared dead by a PO after it threw a connecting rod through the carb side of the crankcase. Another fellow who happened to be a terrific farm mechanic made a patch using a piece of soft metal which he formed to the shape of the crankcase. He then drilled and tapped holes in the crankcase about every inch and bolted the patch & a gasket onto the side of the block. He ran that engine for years until I bought it from him. No welding required!
WC, CA, D14, WD45
GARY(OH/IN)
Orange Level Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
I patched an Oliver 88 with JB and it never leaked again for the several years I owned it.
cottonpatch
Silver Level Joined: 17 Nov 2010 Location: VIRGINIA Points: 285 |
Belzona 1212 is a better fit as it’s oil tolerant so you don’t have to sweat it. Also available in smaller kits, and it’s one to one base to solidifier versus 3:1 for super metal. Both good products. |
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
The metal patch idea works pretty good, for large holes, drilling, and tapping, too. I hadda jeep that I fixed with jb weld, crack was along the bottom of the water jacket, perilously close to the oil gallery. Its always a good idea to borrow or rent a magnaflux unit, to see how far the crack(s) go. Drill a hole, at the ends, tap and thread in a bolt, at all ends, to keep the crack from growing, taking care not to drill too deep, and into a moving part.
Then there's this: [TUBE]Pq0wfU4ZaKk[/TUBE]
Gerald J.
Nevada Cylinder Head shop on the west side of Nevada, Iowa welds blocks often. They also can straighten crank shaft bores.
Gerald J. |
