D15 series II Front Oil Seal Replacement
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Topic: D15 series II Front Oil Seal Replacement
    Posted: 16 Jan 2020 at 12:04pm
Has power steering. Front oil seal is dripping. Can I replace the seal without pulling the front support from the tractor?
Edited by GregLawlerMinn - 16 Jan 2020 at 12:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 1:01pm
It will be a lot easier in the long run if you pull the front support and oil pan off along with the timing cover if you only want to do it once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2020 at 4:52pm
Did my D14 last winter.  Best to pull the axle, you need a gear puller to pull the crank pulley off.  You will also need to remove the oil pan to get the seal and timing cover centered properly.  Going to be doing the neighbor's D15 in the next couple of weeks.
