D14 Power director
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D14 Power director
    Posted: 13 Jan 2020 at 7:45pm
My mechanic finally finished rebuilding the transmission in my 1959 D14 - it was only in his shop for 6 years!  Now that it is as good as new, the hand clutch needs rebuilding too.
The rear hub clutch (part #70228071) is what I am looking for.  My AGCO dealer says they are no longer available.  You can see mine has chunks missing out of the teeth.  Looking for one in excellent condition or NOS.
I have also heard the clutch plate assembly (Part #70232080) is available aftermarket.  Does anyone have a price for these?
Many thanks!
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 5:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 5:54am
wife would say you need to come down and buy #3 from me.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 11:21am
All of the friction and steel separator plates are available both from Agco and aftermarket. I went through my clutch on my D17 and if I remember correctly there are 7 of each plate and the steels were about $40 each and the friction about $60 each. Then there's the roller lock plates and a center plate. To fix the clutch correctly so it stays fixed is not an inexpensive endeavor.
Off the top of my head you will also want the 6 rollers, new pin lock rings, 6 separator springs, new O rings for the power director shaft and PTO lever shaft, new transmission input shaft seal, new PTO shaft seal on the transmission side.
I might be leaving something out, but this is a very good start to do a first class repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2020 at 9:17am
I have most of the parts I need, except for the rear hub clutch (part #70228071) - pictured above.  I posted an ad in the classifieds.
Please send me a PM if you have a good one.
Thanks very much!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2020 at 9:50am
If you were not North of the boarder, I have a complete D15 power director I'd sell you. Unfortunately I've had nothing but problems with dealing into Canada.
