Track Roller Lub |
Ullrich Farms
Bronze Level Joined: 19 Mar 2018 Location: Haskell OK Points: 22 |
Posted: 07 Aug 2019 at 8:36am |
Servicing an HD6B and need to know what is a good track roller lubricant?
Thanks for any recommendations. Ullrich Farms |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41201 |
the rollers use a gear lube oil which is added using a tube incerted into rollers and allowed to fill cavity until oil flows back out around the tube . I have heard of people using a 000 grease also and adding it by same method .
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4346 |
Anything is better than nothing. I have a Cat with "sealed for life" rollers, notice a little oil leak and before I knew it,it was junk. So the next one that leaked, I filled right away with a 00 grease it has gone 100's of hours. I have been told the Cat sealed rollers are filled with 30 wt,real thin anyway.
I assume your HD6 still has what they called 1000 hour roller rather than sealed for life. In the day the right grease was rather thin about the same as is called "corn head grease" today.
