912 H Making into Hydro Lift |
Doug Acord
Bronze Level Joined: 03 Oct 2010 Location: Indiana Points: 117 |
Posted: 10 May 2019 at 8:21am |
I Have a 912 H that is manual Lift now. I Have a 7117 simplicity roller with all the hydro lift parts. I know I need the spring and valve out of the 7117 pump. I also know I need everything that was attached to the hydro lift on the tractor. Is there any reason why this swap should not work?
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8151 |
Good question. I'm woundering same thing
Roger Nolin
Silver Level Joined: 12 Sep 2009 Location: Monroe Iowa Points: 189 |
It will work. Just put hydro lift on My 914 with electric lift. We had to change the rockshaft the lift handle on because the hyd cylinder is bigger than the electric cylinder. Soak your lift handle where it mounts on the shaft so it will slide off easy.Good luck. Hydraulic lift is so much easier for me than the toggle switch on the electric lift and a lot easier on the batter
