Need help finding Serial Number on WD
HopeSpringsFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HopeSpringsFarm Quote  Post ReplyReply Direct Link To This Post Topic: Need help finding Serial Number on WD
    Posted: 19 Aug 2018 at 12:18pm
I inherited my Grandfathers Allis Chalmers WD and am looking for the Serial number. I know it is supposed to be on the top Left Brake differential, but I am still struggling to find it. Can anyone give a detailed description or have a picture of where I should look?
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 12:38pm
Only the older ones have it there. The newer ones have stamped on the rear differential housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote HopeSpringsFarm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 3:54pm
Thank You will look for it there. I have other Antique Tractors never had so much trouble finding a serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HopeSpringsFarm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 4:52pm
I looked on the Rear Differential and it is not there. My Dad and I have been all over that tractor and can not find anything close to a Serial Number.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 4:57pm
looking at back of tractor' to left hand side back side of brake cover' on casting' should be wd- number;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:04pm
Just above the lift arm shaft on the left side very close to the setscrew with the SQUARE head on it.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 5:28pm
See picture
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 7:27pm
I should also mention I have one that is smooth with no number I guess the housing was replaced at some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2018 at 7:32pm
Also to mention that I have one (1950 WD) that has had a later 1952? WD differential housing replaced. About anything can happen out there in the real world!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HopeSpringsFarm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 4:11pm
Thank you for mentioning this. Apparently something similar has happened to my Grandfather's WD. We cannot find any number on that tractor.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2018 at 5:13pm
Welcome to the forum HSF!
Question:
Is the drawbar a pin hitch or snap coupler and bell?
That "may" narrow it down some on the year as the WD's started out with a pin hitch until they went to factory snap coupler and then the farmers started converting them over. HTH.
Edited by Jim Hancock - 21 Aug 2018 at 5:15pm
How blessed we are by HIS GRACE!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 7:26am
The engine serial number might get you pretty close to year of manufacture, if the engine block is original. I believe someone on the forum has an engine serial number index.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 7:39am
You cannot use the snap-coupler bell as any kind of way to tell the age of a WD. The first WD45's didn't even have it. A WD NEVER had it from the factory, it was always an add-on. When the WD-45 finally did have it available, it was standard equipment UNLESS you ordered it as a "factory delete", meaning it was built without a snap coupler bell.
