Gleaner F pulley part 2 questions
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F pulley part 2 questions
    Posted: 06 Nov 2017 at 7:20am
Ok, I got part of the pulley disassembled. Now I cant seem to get the inner half of the pulley off. This is the pulley that adjusts to change the fan speed on a 74 Gleaner F. I've been told its pressed on, told its just stuck, and told that its on a tapered shaft. I do know it has a keyway on it.   I used a come along and put hard tension on it as even as I could and then heated it red hot. Then used an oak 2x4 to hit the center shaft. Ive only got it to move maybe 1/4" to 1/2". I'm trying to be gentle getting it off so i don't have to buy another pulley.   What am i doing wrong?   I think I'm going to run to rural king tonight and get a three jaw puller. How do i go about getting it back on after the bearing is repaired?
Thanks
Adam
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:08am
That is loctited to shaft. Cut bearing off on other side, remove shaft and take it to a press. Before going back to gather, cut a new keyway under big part of pulley. No need for lactate with keyway in right place.
This was a engineer screw up that they would not change. Every new combine we sold, we pulled the pulley and cut a new keyway where it should be. Never had a problem braking a pulley after that.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 8:25am
OK Mack, I think I'm still a little lost here. Where exactly are you cutting a new keyway? I had considered taking the whole shaft out and having it pressed off at a machine shop. So if I do that where exactly do I need to have them cut a keyway at?
Thanks
Adam
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2017 at 9:32pm
Cut keyway just before shaft gets bigger.   MACK
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2017 at 7:42am
Thanks
Adam
hopefully a smaller picture appears,,,trying something new..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2017 at 7:31am
Got it off. Thanks for the help!
