Bell housing blanket, shield.....???? |
studer automotive
Orange Level Access Joined: 10 Sep 2013 Location: jeromesville,oh Points: 555 |
Posted: 29 Apr 2016 at 5:07am |
And ideas on a cost effective way to make something for my 185? It's a bone stock farm tractor except at some pulls it requires a safety shield , blanket safety cover of some sort for the flywheel. Any body got any pics? Was thinking a cobbling together some
Plates.... |
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4 86 mustang5.0 owned since 8/93 |
Larry W.
Silver Level Joined: 07 Nov 2010 Location: Luck, WI Points: 278 |
My opinion, if it's stock , make a shield, any blankets that you would get will be pretty difficult to use if you want to keep your fuel tank and brackets stock.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4427 |
I don't know the current requirements. My Turbo CA has a blanket that was made by "Chute Metal". It's wide enough to cover all the components of the clutch. Early on the NTPA requirements were a 3/8" x 6" minimum 360 degrees surrounding the clutch. Any place that is was not solid metal and bolted together it must have at least three 3/8" grade 5 bolts per joint.
Larry(OH)
Orange Level Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1576 |
You must be pulling at Wooster this weekend? I bought 2 blankets for my WC and took them back. I am going to fab a bracket to go completely around it. I do not need it pulling the 4mph, so screw it and them right now. Thanks to a dumb A$$ with a JD and a stock flywheel, things have gotten this way
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
studer automotive
Exactly,I didn't do anything. I ran it the way it was. I'm looking at a decent pair of 18.4-34's on pressed steel tims this weekend. Short tire just kill that 185, it spins out way to easy at every pull.
