H3 dozer update |
Post Reply | Page 123> |
OldSchoolRecovery
Silver Level Joined: 06 Nov 2015 Location: Eagle River, WI Points: 301 |
Posted: 26 Dec 2015 at 10:52pm |
Waiting until after the holidays to send in the block and get it checked for cracks. And for some mad money to pop up!!
Still debating on the crankshaft, grind for 040 on the rods or get a new one for $400...
cb1 |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
How's this project coming?
OldSchoolRecovery
Got the motor on the motor stand and stripped of all parts. However, under the oil filter mount, there is a hole with a ball bearing (about 3/8" diameter) in it. Anyone tell me what it is and or how to remove to clean. Or if you just leave it in. Anyway, the block will be going in to be shot blasted (cleaned) and magnafluxed for cracks, this week.
Thanks, cb1
Edited by OldSchoolRecovery - 14 Dec 2015 at 1:14am |
orangeman
Orange Level Joined: 12 Sep 2009 Points: 1694 |
OldSchool: Might check to see if someone is parting a G-138 or G-149 Power Unit for a useable crank.
Orangeman
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3303 |
glad to see you got those pistons out when we rebiult the wd45 when we got it back i let those same two cyliners soak in atf and acitone for a whole summer, then still had to chain the tractor to the shop floor and jack the piston and sleaves out in one piece could not believe it did not break the block but we still did send the block to the machine shop and the mains line bored got rid of the shims and had cam brgs installed pressed one assy apart in the press to see how far the stuff had penitrated it was only about a 1/4 inch all summer long
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 890 |
You are really good with the wrenches!! You have the virtue of being able to stay focussed. My Dad, soon 82, is the same, once he tears into a tractor he stays on it 'til it's finished making very good use of time. I wish for more of the same for myself
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33664 |
Sugarmaker, It looks like he's yanking that old model A motor out to put in his crawler. LOL
OSR, yur makin progress...
Sugarmaker
Looks like a little more power!?
good shots! Maybe this will get me going on some of my projects:) Regards, Chris |
OldSchoolRecovery
New motor getting ready to go in!!
OldSchoolRecovery
OldSchoolRecovery
Got the motor out. Took all of about an hour.
OldSchoolRecovery
OldSchoolRecovery
OldSchoolRecovery
JC-WI
There is 20 megs of space... I have over 160 pics in there.... I need to delete some since I am getting close to maxed out. ... but that has been since sept. 2009. Guess its time for a cleaning. LOL
OldSchoolRecovery
Pictures are back,
cb1
OldSchoolRecovery
I did. Didnt want too many on there and I did not know that they would be gone. Not sure if I put them back in there that they will show, but will try..
cb1
JC-WI
Old school, did you delete pictures off the Allis storage site? All your first pics are showing up as a boxed X.
JohnCO
Seems like getting a new crank is the way to go, expensive but in the big picture, the engine will be just like brand new. 040 over is a lot and a potential problem down the road, imho.
Allis Express participant |
OldSchoolRecovery
I see rod bearing for sale at .040 over. Seams like a lot to me. Any thoughts?
cb1
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10567 |
Grinding your crank will be a hundred plus dollars. Buy a new one, you will save money on it and the bearings. Check the block,oil pump and galleys. A very stout engine if running correctly. Good Luck. |
OldSchoolRecovery
Yep, cb1
OldSchoolRecovery
Where the crank stopped I can read M020, R030 and another number. So shes been rebuild before.
Rods at 030 is a concern as Im not too sure if they (Allis) surface hardened thier cranks and to what thickness. I see they have new cranks out there for $400. A little pricey but may have too... cb1
Edited by OldSchoolRecovery - 23 Nov 2015 at 9:30pm |
OldSchoolRecovery
New pistons, rings and sleeves are $90 a pop, so not too terrible...
cb1 |
JC-WI
Well, I didn't count on pistons running dry before the bearings got wiped out... and then the rust formed on that dry steel...
you are right, your in for a full overhaul... and get that block cooked. Check the oil pump too, see if theres rust in it and make sure the little springs that hold the vanes apart are good. Hope the pistons are salvageable.
OldSchoolRecovery
Ok, Arhggg, had to pull the sleeve as I could not get the piston to move freely enought, i.e. with the starter, etc.
Glad I did as it looks like the rod bearing(s) are wiped out. Looks like a complete now. Pressed the piston out of the sleeve, yuk.. Oh, and I think I solved the riddle. They (???) left the skid pan off and put a whopper of a dent in the oil pan, which in turn lifted the oil pickup out of the oil and walla, no oil, wiped bearings. Then left out in the rain. The good news is I really like this machine and how its put together. Simple enough for even me. And it doesnt look as bad as the pictures. Now, pull the motor and put on a stand and the dozer on trailer back outside until the motor is dun. cb1 |
OldSchoolRecovery
OldSchoolRecovery
OldSchoolRecovery
Eric B
You are well on your way. You do have the advantage of the pistons being high up in the sleeves...will be easy to hone out the deposits of crud once you're down a bit more. We'll look forward to your next report.
