Rake Model? |
AJ
Orange Level Joined: 31 Oct 2010 Location: mo Points: 5244 |
Posted: 26 Mar 2016 at 1:05pm |
Can anyone tell me what model rake this is? I can't find an ID tag anywhere or anything.
Edited by AJ - 26 Mar 2016 at 1:05pm |
Can't fix stupid
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4842 |
I'm not the expert on the newer rakes, but my guess is that since it's a 4 bar one it is a 77G
Bill Deppe/AC Salvag
Orange Level Access Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 972 |
Agree with PaulB, have a couple that I use and added the fifth bar
ctbowles58
Orange Level Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
yes it is a 77G......The model 78G had a crooked rear axel..77 Is straight. and it could of been either a 4 or 5 bar, the 5 bar was a option.............I have a 77G, and just bought another one this morning.
Edited by ctbowles58 - 26 Mar 2016 at 1:55pm |
AJ
Was that the only difference between the two was the rear axles? This one needs a part or two for the drive pulley. Anyone have any parts for them?
Edited by AJ - 26 Mar 2016 at 2:59pm |
Can't fix stupid
ctbowles58
ctbowles58
Here is a pic. of my 77G....
AJ
Does anyone have a dealer PDF parts manual they could email me? What were the factory tire size for these?
Can't fix stupid
Ky.Allis
Orange Level Joined: 31 Jan 2010 Location: Kentucky Points: 1012 |
The purpose of the offset(crooked) axle is by being closer to the basket it will follow ground contour better. At least that's what NH said when they went to the offset axle. I've used both styles of NH rakes and see very little difference. I would like to have a AC rake but since parts are impossible to find I will stick to my old NH 55 rake.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
My neighbor has a 77 rake and the clutch is shot on it. They put a hose clamp on it to keep it engaged and just derail the belt to take it down the road if they have to. I've been after him for years to let me tear it apart and make a new clutch for it. He just says , "it's no big deal, works OK like it is."
ctbowles58
ctbowles58
Here is a pic of the one I bought today, I got lucky it has a good clutch.
Dave (NE)
Orange Level Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2152 |
Well, per my 77G manual, it lists tire sizes as: 5x15, 5.90x15, 6.40x15 and 6.70x15. I'd have to go out and look at mine to see what size tires are on it, if you are interested. Let me know. Dave
ctbowles58
Here is a pic of a 78G
Don Jr NY
Silver Level Joined: 11 Sep 2009 Location: Waterloo NY Points: 342 |
You have the later model 77G as others have said because it has the belt drive like the 78G. The early 77G had a chain drive to a gearbox that was on the basket similar the the New Holland setup. HTH. Don Jr.
ctbowles58
TedBuiskerN.IL.
Orange Level Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
I put the 5th bar in my 77G, then went to larger tires. Better traction, and it slowed the rake a bit which was OK with the fifth bar. I had the same problem with the clutch wearing out and solved it the same way. I used muffler clamps and took them loose when I needed to go down the road.
I also have a 77M with all new teeth.
Dave (NE)
I checked the tire sizes on my 77G rake. One was apparently an old vehicle P195/75-R15 and the other an old truck tire 78-15. I don't know how all these crazy tire sizes translate, but the 78-15 stands a little higher than the other throwing off the level adjustment. I also have a 77M. The tires were shot on it when I got it and I found a couple NOS 16x6.50-8 tires and put them on. Manual says to use a 4.0 - 8 size tire, so don't know how this affects the operation of the rake. I have had trouble with the lift arms of the rake popping out of the tractor lift arm latches. Don't know if this is due to uneven ground surface, tires/tire adjustment or something else, but usually just use my 77G instead. It is a nice working rake. Dave
Trinity45
Orange Level Access Joined: 17 Mar 2014 Location: Kentucky Points: 1735 |
We had one that looked just like that except it was chain drive, good ole rake, sold it to a man down the road, still going strong.
Dave (NE)
Yeah, my 77G is chain drive. Why did they change that and go to belt drive? Always kinda wondered why. Dave
CTuckerNWIL
Maybe a couple reasons, cheaper first and second, it might lend to a "softer" drive in case something needed to slip. Just my guess.
Dave (NE)
Some pix of the 77M
Dave (NE)
77G with chain drive
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10666 |
You can change the speed of a belt drive by moving shims on the sheaves. HTH Tracy |
