bearing |
bs5230
Topic: bearingPosted: 29 May 2010 at 8:10pm |
i was trying to find where to get a new bearing, it goes on the transmission end of the shaft that goes through the hand clutch- it has a big snap ring on it, the bearing itself goes into the houseing of the trans this is on a 1951 wd
Edited by bs5230 - 29 May 2010 at 8:11pm |
Joined: 11 Sep 2009 Location: illinois Points: 89337 |
Posted: 29 May 2010 at 8:16pm |
you can probably buy thru local AGCO dealer or on line AGCO, but the cheapest way is to order from Motion Industiries or Bearing Supply house, etc.. There should be a number on the bearing race and manufacturer such as SKF, FAG, etc. The bearing is not specific to the WD. Most bearings are generic.. In a pinch i have gone to NAPA auto store and they will order it.
bs5230
Posted: 29 May 2010 at 8:25pm |
i looked all over the bearing and did not find any numbers or letters at all, i will try to find it on one of the sites- i could not find it in the I T manual either
Posted: 29 May 2010 at 8:35pm |
sorry, i donthave a parts book for the WD-- maybe soneones has the number.
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Posted: 29 May 2010 at 10:25pm |
Try taking it to your local bearing shop - if it's more or less in one piece they can measure it and get you going.
WC, CA, D14, WD45
ac612bill
Joined: 29 May 2010 Location: Dothan, AL Points: 12 |
Posted: 29 May 2010 at 11:00pm |
I have several nos bearings I can look through but I need to know if your serial No. is before or after serial number 127007. I have the one pictured #224837 for the tractors before #127007
