G230 vs G226
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: G230 vs G226
    Posted: 11 Jan 2016 at 12:02pm
Does the Buda 230 gas have any advantage over the 226?
More torque?
Looks like it revs more.
Charlie
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2016 at 8:14pm
could you narrow the question a bit. What are the uses of the power plants?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 5:30am
Say a WD45 Diesel but with a 230 gas vs a WD45 226
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 8:33am
I've watched 230 gas powered tractors at the tractor pulls and they can really light up. That's the only experience I have had with them. Similar to the 262 in my D19. Nice smooth power in the 262 with good power but no where near the governor action as a 226.
Edited by Lonn - 12 Jan 2016 at 8:35am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 9:53am
If there ever would have been a WD-55 or a D-18 tractor, my guess is, the G-230 might have been the engine of choice (at a higher RPM). As it was, the four cylinder did the job and probably cost less than a six cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 10:14am
Just dreaming on a cold day.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2016 at 12:55pm
My vision for years of the WD-55 was the G-230 @1800 RPM with an 11 inch diameter foot clutch, an 8 inch diameter triple disk hand clutch and a 7 speed transmission with 3-speeds faster than each existing gear (for in-between speeds) except road gear, a longer wheel base and 16.9 x 28 tires. Could have been a real contender in the 53 HP class in 1953.
JoshL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoshL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2016 at 11:52pm
We ran a 262 in a cockshutt we had. They are strong motors.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 9:58pm
There were a few D18 prototypes. According to Swinford's book "Allis-Chalmers Farm Equipment 1914-1985" the D18 didn't meet the hp requirements the sales people had wanted. I think is used a detuned 262 if I remember right.
Edited by Lonn - 10 Feb 2016 at 9:59pm
Wink
I am a Russian Bot
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2016 at 10:29pm
back in the day a lot of the 262 gas were put in small dump trks. farm trks. etc, and worked well . Now if you took a 235 head, opened up the water passages in the end of the head and did nothing else you could work the heck out of the small V8,s. It really woke that little 262 up.    Leon  Cmo
This page was generated in 0.199 seconds.
