restoring a b model
dano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dano Quote  Post ReplyReply Direct Link To This Post Topic: restoring a b model
    Posted: 22 Dec 2015 at 8:04pm
hey guys im new to working on tractors, but have bought a 1948 b model a/c I have read some stuff about rebuilding the motor and other things ,but heres my question, I found the serial number by the gear shifter, it shows b575 then a space and 12 at the far right side so now im not sure of the year ,anyone that maybe able to steer me in the right direction as the correct year would be helpful thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:18pm
Dano, I assume this is a small farm tractor model B... On this site it is not called a garden tractor, but a farm tractor. You should repost in the farm tractor section. The serial numbers were hand stamped. The space between the 575 and 12 is just human error....... your number is  B57512.  The motors are very similar from 1940 up thru the late 1950s. The piston diameter  changed slightly and older models may have the larger size. Many tractors have been "changed" over the years so the model year is not really important. Post in the "farm tractor" page and put in a photo if you can. Ask all the questions you want. Plenty of answers here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:20pm
Year Starting Serial Number
1937 1
1938 101
1939 11800
1940 33394
1941 49721
1942 56782
1943 64510
1944 65502
1945 70210
1946 72301
1947 73370
1948 80056
1949 92295
1950 102393
1951 114258
1952 118674
1953 122310
1954 124202
1955 124711
1956 126497
1957 127186
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:22pm
Do you have an electric starter ?  foot brakes or hand brakes ?  Generator ? Hydraulics ?
dano View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dano Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 9:26pm
thanks for answering, yes it has elec start foot brakes and gen im new to this site as well as working on tractors but thanks for your info
This page was generated in 0.172 seconds.
