WD for sale
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: WD for sale
    Posted: 30 Apr 2010 at 4:34pm
Late WD, has WD-45 transmission, shifter tower rebuilt, new temp Gage. three bolt wide front. Matched set of rear tires (50-60 %), the normal rot around valve stem. The three point hitch and tire chains do not go with it. It's a real strong runner, but does puff a little blue smoke when stating cold. I'd like to get $1500, but will entertain offers.
The hour meter and traction boost gages do not work. The hydraulics and PTO work fine. I will put a couple of pics here, if you are interested e-mail me, I'll send some more. It's killing me to let this go, but, times being what they are, yada, yada, yada
Also, I rebuilt the carb last year
Edited by LouSWPA - 30 Apr 2010 at 4:59pm
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 4:42pm
Hour meter?
Mike(SEIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(SEIN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 5:22pm
Bob H. Look at the first pic. After market hour meter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 5:24pm
Pics.didn't show up 1st.time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:08pm
Damn Luigi! You got some iron sittin' around there. You better git' goin' on some of that stuff brother! LOL!!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:17pm
Steve@B&B
Steve,
that's why I'm parting with some stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:18pm
You are correct, I was slow in getting the pic up!
ChuckLuedtkeSEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 10:32pm
I'm suprised.  I would think with the wide front, good rubber all the way around and the condition of the tin, she would be gone already.  Nice tractor Lou, wish I needed another project and we were closer.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 10:51am
Might be a dumb question, but how SHOULD the hour meter operate? Is it just electronic based on if the tractor is on or not, or is it hooked up to the engine and measures RPM's or something?  I guess I just don't know.... and am curious.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 11:09am
Jacob,
Not a dumb question at all. I don't know for sure, because it has never been connected since I bought it, but, I suspect that it is simply an electric clock movement that is energized from the ignition switch.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 4:52pm
I have that same hour meter, was wondering if there were any others around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 10:14am
OK, bumping this up, open for offers. I do have a better grille shell and fender that can go with it
realolman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote realolman Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 10:55am
where is this located?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 2:20pm
North west of Pittsburgh, Pa, intersection of state rt 18 and US 30
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 2:28pm
Lou what do you want for the wc flat top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 4:14pm
PM sent
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2010 at 1:41pm
I believe the hour meter works off of the engine oil pressure. My dad's WD45D had one just like it when he got it. There was a sending unit that was on a tee in the base of one of the oil filters. The sending unit had two screws for wires that ran to the hour meter. His hour meter works fine, unfortunately the sending unit does not work.
