9690 wheel ballast
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Topic: 9690 wheel ballast
    Posted: 27 Apr 2010 at 8:25am
I'm putting new shoes on my 9690. They had calcium chloride in the old tires without tubes. I would like to go back with some type of liquid. What do you folks think. Calcium Chloride, antifreeze, or methanol, and should I use tubes or tubeless. New tires are Firestone 18.4x46 23 degree deep lug radial, plus adding FWD tires and should I put ballast in the front, I have half of the front weights on. Our temps usually drop in the single digits every year and below zero about every 4 or 5 years. Coldest I remember was 11 below back in the 80's. I am leaning toward methanol and tubeless because it is not as corrosive.  Thanks
Edited by Kevin(Alabama) - 27 Apr 2010 at 12:55pm
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 10:15pm
Kevin, I'd be a little leary of going tubeless with any kind of fluid in them. On our 8050 we had went tubless with calcium chloride, and eventually had to put tubes in anyway. It was probably because they were power adjust rims, and they started leaking wherever there was a weld holding the spiral rail on. You might be OK if you have regular rims. I don't really care for  any fluid in tires, but I realize that it is kind of a necessity to get your power to the ground.  Darrel
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 11:10pm
i would never go tubeless with or without fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 7:59am
Thanks Darrel, Jordan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 6:10pm
Run the front tires half full of fluid and you'll get rid of the "bounce" when going down the road at 25 mph.
This page was generated in 0.289 seconds.
