D17 Connecting rod Toque
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Topic: D17 Connecting rod Toque
    Posted: 25 Apr 2010 at 10:56am
Does anyone know the torque setting for connecting rod nut for 226 engine..I looked it up says 45-55ft lbs with locknut or 70 ft lbs with castle nut..Is this the rod castle nut or locknut.. just stumped now. Having a moment of CRS!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 11:00am
That is a castle nut. The slots are for wire tying through the hole in the bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 11:24am
Thats what I was thinking but upon looking at the rod bolts I see no holes to lock the nuts..
Dean SW IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean SW IA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 11:48am
That is An old style lock nut that was used back then.
            Dean SW IA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 11:51am
so I should be ok to torque them to 45-55 and be done with them??
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 4:04pm
Typically lock nuts are replaced  after each use. After the nut has been on and off its locking qualities diminish.
