CA hydro's dangit.
akmarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Topic: CA hydro's dangit.
    Posted: 15 Apr 2010 at 11:52am
My 52 CA runs great I just don't get to use enough.My problem is the lift,I can't seem to find the spot that the lift will stop raising.just repainted seat from damage 3rd link did to it.Is there some adjustment I'm missing or is it internal? it will almost stop but still creeps up or down slowly,seems to work fine otherwise,plenty of lift power.3 days ago it got me in the lower back and dented up the seat real bad.Any ideas what is wrong?
thanks Marty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 1:17pm
If the 3 pt is set up right you should be able to raise it all the way up without hitting anything. There is a hold position valve that should hold it part way unless it is not working properly, which sounds like the case. It sounds like the top link bracket is not positioned properly to allow full lift without hitting the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote akmarty Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2010 at 8:43pm
Thanks Charlie I'll check that.
