Tractor and plow ?
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Topic: Tractor and plow ?
    Posted: 12 Apr 2010 at 7:42pm
Will my D19
with this AC 3pt hitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 7:45pm
And this plow work togather.
Roger Nolin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Nolin Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:00pm
I think it would, can't see why not.< id="gwProxy" ="">< ="jsCall;" id="jsProxy" ="">
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:09pm
It should take it with ease.  You will need to take all sway out of the 3 point adaptor to keep it in control making full use of the steering of the plow.
When a semi-mount is used for instance on my 185 it has to have the sway blocks on-no side movement.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:23pm
Yes it will hitch together, no it will not work as it should. A 3 point mounted or semi mounted plow needs one of two things to maintain any kind of even depth. A combination of draft and position control, or a gauge wheel, you have neither.  If your hold works well on the lift arms you might be able to use it and the traction booster to maintain some semblance of even depth but I wouldnt want the job of trying to keep up with the levers for too many acres.
EdIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2010 at 8:26pm
That 3 pt adapter is a little on the light side to handle the lateral force and weight of the 4 bottom plow.  The adapter typically breaks near the front weld on the left hand side.  I've seen many broken with a lighter load applied.  Also, the vertical adjusting link on the left hand arm on your adapter is usually on the right hand side to level the implement when the tractor is in the furrow.  Good luck!
