B/C governor question what gives here? |
Dave Everett
Orange Level Joined: 12 Sep 2009 Location: England Points: 875 |
Posted: 11 Apr 2010 at 1:37am |
just rebuild a B from different pieces, now throttle has only 2 positions, tickover, open one snotch then is flat out, im missing something here but i cant think what............ can I have some advice please...
thanks in advance.............
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5054 |
Sounds like the governor is not working.
Dusty
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
Rather than type it over for the umpteenth time I will give you a link.
Cross Over Arm Adjustment http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ac&th=125547 |
Bill Deppe/AC Salvag
Orange Level Access Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 970 |
Be sure the thrust bearing is correct on the shaft
norm [ind]
Orange Level Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |
every thing is not adjusted to specs start over dave throtle wide open go to left side carb wide open is linkage close to hole behind the fan should slidein with everything wide open if not bend to fit my 2 cents
Dick L
Either way Norm. The only way it would not work wide open is if the link from the cross over arm was not a proper match. In that case you would have a high RPM high or low depending on the length of the link. I have bought tractors with home made link rods. I also bought one that had a piece welded to the cross over arm.
In calling out setting in the idle position is showing that the governor at idle is not holding the the butterfly back against the butterfly stop screw. |
norm [ind]
go to a stock set up try again
